Old 03-25-2016, 09:44 AM   #43
richw46's Avatar
Lexington , Kentucky
Originally Posted by cactusjk View Post
Assume a 23' would have the same rubbing as larger?
Are you sure you're opening the awning correctly? I started this thread when I first got my AS and I wasn't opening the awning all the way, so the door was hitting the awning. I watched the video on YouTube and saw I wasn't extending the rafters and support arms all the way. The video really helped and now the door barely touches the door if it's raining and the awning sags. Otherwise, it's fine.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 03-25-2016, 09:57 AM   #44
2015 23' Flying Cloud
Livermore , California
I was thinking of when the awning is not fully deployed due to wind, etc. that it might be nice to have the door roller.
cactusjk is offline   Reply With Quote
Old 03-25-2016, 10:07 AM   #45
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
WBCCI caravan people recommend you cant the awning to prevent puddling of rain. The rain will spill out the back. Roller hardly hits in that circumstance.
Old 03-25-2016, 10:08 AM   #46
So is the roller a good idea just in case?
Old 03-25-2016, 11:15 AM   #47
1976 31' Sovereign
Oswego , Illinois
Simple YES.
Old 03-25-2016, 07:04 PM   #48
I went up to Bay Area AS today and did not see one door roller installed. Also, all the AS with awnings open did not rub on the door albeit they were fully open. Additionally, Service didn't seem to think they were needed. Guess I will see how it works out and decide later.
Old 03-25-2016, 08:27 PM   #49
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I would highly recommend a roller. There are times, for whatever reason, that you might have the awning deployed but not have it fully extended up. Like when you are deploying the awning, someone is in the trailer and not paying attention to what you are doing, and tries to exit the trailer...... That roller coming in handy just one time is well worth it.
PaulnGina
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
Blessed and highly favored
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
PaulnGina is offline   Reply With Quote
Old 03-28-2016, 05:22 AM   #50
2016 30' Flying Cloud
Oviedo , Florida
I STRONGLY recommend never putting the awning up with both arms fully extended (on the fourth hole) and the awning level because if it rains any significant amount, the fabric will sag, water will collect and the weight will collapse the awning and bend the s**t out of one or both arms. Don't ask me how I know this
If you deploy the door end at 4 holes and the opposite end at 3 holes, the door will normally not rub with a dry awning. However, as it gets wet (even though it drains fairly well due to the slant) the fabric will sag slightly and you may rub.
If I am going to leave the awning up in steady rain for any length of time, I lower the one side to 2 holes to provide a more extreme slant to make sure water doesn't collect. On every trailer I have owned or seen, the door will rub in that position.
Keith & Barb
2016 Ram 2500 diesel
Southeastern Camping Unit, WBCCI #1675
khollister is offline   Reply With Quote
Old 03-28-2016, 09:50 AM   #51
1998 30' Excella 1000
Livingston , Texas
One other caution. On my awning the slot/gap where the claw arm fits on the pin next to the roller tube is very narrow. I once raised one end all the way up and it levered the other arm enough to crack the claw. I now raise one end 1/2 way, then the other end all the way, then go back to finish raising the first end. I don't know if the newer awnings have the same tight tolerance as mine. Or if they have the travel lock mechanism on the end of the tube, which I think contributed to this issue. But worth checking out.
Siegmann is offline   Reply With Quote
Old 04-05-2016, 06:00 AM   #52
SDP 28 FC's Avatar
2016 28' Flying Cloud
Glen Rose , Texas
Door Rooler Installation
Originally Posted by AnnArborBob View Post
This is what the awning door roller looks like from Zip Dee. This is intended to allow a door to gently roll under an awning that lightly scrapes the top of the door when opening. It is not intended to address the issue of a door being blocked by the awning at the 2/3 or 1/2 way open point. It sounds to me as someone has previously indicated that your awning is not being fully extended.
I have to install a door roller (received one from Zip Dee) because the door rubs the fabric with the awning properly and fully extended. I am nervous about drilling holes in my new 28' FC and want to make sure I get it exactly where it needs to be.
SDP 28 FC is offline   Reply With Quote
Old 04-05-2016, 06:22 AM   #53
PaulnGina's Avatar
Good Ol' , USA
Here is a picture of our Avion that shows where the roller is placed on the door. It will give a good idea of where to mount it. Notice that it is placed high on the door, just below the upper frame of the door. (When you are viewing the picture, you can enlarge it by pressing and holding the Ctrl key, then press the +/= key)
1987 Avion 34W
Old 04-05-2016, 03:13 PM   #54
Does anyone with a 23 have trouble with the door rubbing the awning? Rethinking the door roller again!
Old 04-05-2016, 03:50 PM   #55
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Only if I unintentionally and negligently forget to run the extensions all the way to the forth hole.
MICHAEL
Old 04-05-2016, 07:36 PM   #56
richw46's Avatar
I'm the one who started the thread and it turned out my problem was not extending the rafters and supports all the way. Watching the Zip Dee video on YouTube really helped me. My door barely touches the awning, mostly when it's raining. When the awning is dry there is no problem. I'd say if you watch the video and you're doing everything correctly, then you might have to install a wheel.
P.S. Before I found the video telling me what to do, I found I could put a 20 oz. Vitamin Water plastic bottle above the door, under the awning cover. It raised the awning just enough to clear the door. But setting up the awning properly takes care of that issue and I don't get funny looks or questions about the bottle from visitors.
-Rich
Rich & Yvonne
2004 4Runner SE
2 way or 3 way Stefandmissy General Repair Forum 12 05-04-2014 07:59 PM
Inexpensive way to protect your 7-way plug SmokelessJoe Lights - Interior & Exterior 6 03-05-2011 02:08 PM
2-way vs. 3-way Dometic loriday Refrigerators 12 08-15-2010 09:21 PM
2 way or 3 way Refrigerator? New or Old? prairieschooner Refrigerators 10 09-13-2006 09:45 AM
What is 2 way vs 3 way fridge? Astrodokk Refrigerators 12 06-01-2005 03:33 PM
