07-12-2018, 08:15 AM
1965 17' Caravel
Grand Rapids
, Michigan
Awning ideas for 65' Caravel
Hey folks,
My wife and I are new owners of a 65' Caravel and are new members to the forum!
We are hoping to install an awning. I know I've read somewhere about the Zip Dees not working.
Does anyone have an awning on theirs and what are you running?
Thanks for the advice!
Steve
07-12-2018, 05:19 PM
1965 22' Safari
Rescue
Hi Steve I have a 65 Safari that we restored and went with Zip Dee without any problems. Great people to work with, although I spent more for the awning than I did for the trailer
The St Pierre's
08-27-2020, 11:48 AM
1965 17' Caravel
Fairview Heights
What did you end up going with?
09-10-2020, 06:29 PM
1967 17' Caravel
Oakland
I'm looking for an awning that is not a Zip Dee. Something that is unique. If it takes a half an hour to put together I'm OK with this. I just don't want to be like everyone else on the block.
09-10-2020, 06:55 PM
1966 22' Safari
Fredericksburg
On both our trailers my wife made the rope and pull style period correct awnings. I think she used Sunbrella material on one and some other manufacturer on the other. We added a spring and pulley to the pole ropes so the awnings could handle winds. It takes us under 10 minutes to set up.
09-10-2020, 07:42 PM
1967 17' Caravel
Austin
I have a vintage rope and pole awning on the way from Vintage Trailer Supply for our 67 Caravel. Does yours already have the track/slot on the trailer?
09-10-2020, 07:57 PM
1966 22' Safari
Fredericksburg
Yes it does. Each time I put it up I spray the track with dry lube. The springs on the ropes really help with the wind. Ours do have the channel on the top side. If yours doesn’t, I guess you could attach one with Olympics. I think VTS sells the channel.
09-11-2020, 12:12 PM
1966 17' Caravel
1972 21' Globetrotter
SW
, Missouri
66
I have Zipdee all around on my 66. I can post pictures if anyone still wants to see them.
09-12-2020, 12:21 PM
1967 17' Caravel
Oakland
I have a track which isn't a problem. I don't want something that is permanently attached to the roof.
09-14-2020, 02:30 PM
1967 17' Caravel
Austin
My '67 has the track. Awning showed up Friday, but still in the box as my trailer is in remote storage until next trip...can't wait. Saw a video on Youtube of a guy setting up his awning by himself. He rig a pulley system that he stuck in then end of the track and pull the awning through the track with a rope as he feed in the fabric. Might try the same thing.
09-14-2020, 02:36 PM
1966 17' Caravel
Pine Plains
, NY
Hi David - Could you please provide a link to this video? I too am trying to sort out the best solution for an awning. Thanks.
09-14-2020, 05:31 PM
1966 22' Safari
Fredericksburg
David, I tried the pulley at the end of the track. It kept binding. I’m sure you can get it to work, but it doesn’t take any time to start the cord and pull the rope. We spray our track periodically with some dry lube for sliding ease. Also, we clean the track one a year. Takes less than 5 minutes. You can take a 22 caliber barrel cleaning wire brush on the end of the first section of a gun cleaning rod. Bend the brush at 90 degrees. The brush slides in the track with the rod perpendicular to the track. Cleans any dirt daubers out. Lastly, we got fiberglass paint poles at Lowe’s and the paint roller screwed on the end. Cut the roller thingy off leaving a couple of inches for your rope loop. Also, where you hook your rope over your landscape spike (with a 3/8” washer) place an 8” spring with a rope pulley. That helps when the wind blows allowing the awning to bellow a bit without pulling out the spikes. Good luck
09-17-2020, 05:40 PM
1968 17' Caravel
1967 22' Safari
Leawood
, Kansas
Vanster- thanks for posting your pics. I don't have a track and when I was eyeballing my trailer, I thought my Fridge vent and my stove exhaust vent didn't align, but I'll take another look. I don't want a bulky Zip-Dee on the curb-side. Jerry
09-17-2020, 09:38 PM
2007 25' Safari FB SE
Plano
We installed a Zip Dee awning on our 1965 Caravel. There are two issued that need to be addressed:
1) the awning arm cannot interfere with the door handle
2) the vent cover over the cooktop cannot interfere with the awning tube
Here is ours (sold several years ago):
https://www.flickr.com/photos/531162...7631706699412/
Keith
