Old 10-14-2013, 09:17 PM   #1
redthies's Avatar
1974 29' Ambassador
1968 20' Globetrotter
Whiterock , British Columbia
Awning ID?
I'm trying to figure out which awning I have on the '75 Argosy. Travel Awn 5000? I can't seem to find any markings anywhere. Thoughts? Parts sources?
I am the '68 Globetrotter...
redthies is offline   Reply With Quote
Old 10-14-2013, 10:35 PM   #2
1974 Argosy 20
Kooskia , Idaho
Looks like a Carefree of Colorado to me. Guessing from the curved supports and the bump like knobs on the end roller.
Old 10-15-2013, 09:20 AM   #3
redthies's Avatar
1974 29' Ambassador
Any idea on model name/number?
Old 10-15-2013, 02:04 PM   #4
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
The arm and the roller look like Carefree of Colorado, but the end-cap on the roller looks WEIRD. I think it may be some sort of homemade replacement part.
I'll look at the label on mine to see if I can get a part number or something, but I suspect that the parts for that era are more or less interchangeable, and you'll probably be on your own looking for used parts. I haven't tried, but word is that the company is not intent on supporting old models.
David
Old 10-15-2013, 02:49 PM   #5
WBCCI 8562
Jim in Pima's Avatar
1975 31' Sovereign
Pelzer , South Carolina
this looks identical to the 1975 Carefree on my unit. The end caps are not available
as far as I could tell. The bearing in mine was gone and I ended up with a rube goldburg similar to what you have. However it works.,
Jim in Pima Az, enjoying our 1975 31 ft Airstream Sovereign
Jim in Pima is offline   Reply With Quote
Old 10-15-2013, 06:25 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Carefree, same as my '74 Argosy.
Old 10-16-2013, 08:12 PM   #7
redthies's Avatar
1974 29' Ambassador
My main concern is how far the cap is from the frame. It is a good few inches away, and it is under some spring tension. I can fabricate something if need be to make it work.
I am assuming the 3-4" of steel rod that comes out of the cast piece on the cap should be inside the tube. If any of you that have this style awning, could you take a picture of the end for me so I can see what it is supposed to look like?
Old 10-16-2013, 08:25 PM   #8
DKB_SATX's Avatar
1976 Argosy 28
I'm not sure this is a helpful view. I was taking some photos of the awning last weekend to share with another member with awning issues.
I'll try to remember to take another that shows the space between the arm and the roller tomorrow, the trailer will be right out front getting ready to go.
David
Old 10-17-2013, 11:11 AM   #9
WBCCI 8562
1975 31' Sovereign
Hi I added several photos of my Carefree Awning to my profile, do not know how to enter them here. The left bearing on my awning was GONE. The way they made them
was the bearing was inside (spring side) of the end of the shaft. No way to replace it. It held the spring shaft from sliding too far into the roller tube. I put a couple
heavy washers the size of the endcap on the outside of the spring shaft and put the cap back on. Also a external screw to hold the shaft in place. I have photos on my profile page if interested
Old 10-17-2013, 12:32 PM   #10
DKB_SATX's Avatar
1976 Argosy 28
Here's a view of the area between the roller and the arm.
David
Old 10-17-2013, 11:08 PM   #11
redthies's Avatar
1974 29' Ambassador
DKB, I'm pretty sure yours is the same as mine, but with an updated end-cap (torsion cap?) perhaps? Do you know which model it is? I'm assuming it IS a Carefree?
Thanks for the pics, James
