Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 06-17-2007, 07:51 PM   #1
Davis
Davis's Avatar
Profile:  1991 34' Excella
Americus , Georgia
Awning Fabric Replacement ?
Is it hard to replace the awning material on a carefree awning. The awning is on a Argosy and is 14ft long. If anyone has some instructions I would appreciate that so I can determine if I want to tackle this project. Thanks Davis
1991 Airstream Excella 1000 34ft
1994 Chevrolet Crew Cab dually 2WD 6.5td
2004 Chevrolet Suburban 1500 2WD 5.3
WBCCI # 10219 Georgia Unit
AIR # 5131
Davis is offline   Reply With Quote
Old 06-17-2007, 09:17 PM   #2
Ganglin
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
See if this helps you any.
RV Awning Service
RV Doctor Question of the Month
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 06-18-2007, 05:19 AM   #3
Davis
Davis's Avatar
Americus , Georgia
AIR # 5131
Old 05-16-2008, 09:14 AM   #4
bobfowler
bobfowler's Avatar
Profile:  1972 Argosy 20
2007 Base Camp
Middletown , New Jersey
Images: 14
Originally Posted by Ganglin
I know this is an old post, but I wanted to say thanks for posting the links. I have to put my awning back on soon and had NO idea of how many turns I needed on the spring.
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
bobfowler is offline   Reply With Quote
Old 05-16-2008, 09:49 AM   #5
NevadaGeo
Profile:  1978 31' Excella 500
Genoa , Nevada
Zeppelenium had a post with part numbers and drawings for the ZipDee a few months ago, think it showed some safety tricks on that. Sounds potentially amputatingly interesting.
NevadaGeo is offline   Reply With Quote
Old 05-16-2008, 11:30 AM   #6
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
Bob, when you get the awning put back on, be aware you have to lift the rear arm slightly to get everything to seat in place for travel. It took me quite a while to figure out to unlatch the rear handle, lift slightly, and finish rolling the awning.
Change is inevitable, except from a vending machine
AIR#2611
Old 05-16-2008, 02:22 PM   #7
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
What type of awning do you have, and how long is it? I'll look it up in my tech manuals and get the # of turns for you............
PS: If it's a Carefree, you have to remove the arm and use a Vise-Grip on the end casting to wind it. You then pin the spring to freeze it so you can replace the casting ito the arm.
Zip-Dees wind with the arm ON. It helps to have another person around to hold the ZD away from the coach while you wind to allow you some room for the arm as it passes by the outer skin. We don't want no stinkin' scratches there....now do we?
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 05-16-2008, 02:35 PM   #8
bobfowler
bobfowler's Avatar
2007 Base Camp
Images: 14
I learned that the hard way back in September when we were on our way home from Bat Cave. I find that the front latch id actually harder to handle than the rear. I bought some new hardware a couple of weeks ago to repair the seized knobs on the rafters. Finding the right parts was actually easy!
It's an A&E 8500 Series (I don't have the exact info here). It's a 20' trailer, so the awning is about 10' (once again, I don't have all the info handy).
Liz and I are going to order new fabric this weekend from our local RV supplier (Fitzgerald's RV in Middletown, NJ). The existing awning is probably OK for another season or two, but we might as well replace the fabric now since the awning is already off the trailer. Besides, I think the trailer deserves new fabric to go with her new paint!
Bob Fowler
Old 05-16-2008, 04:27 PM   #9
overlander63
Images: 58
It is indeed a 10 foot long 8500, and I replaced the fabric in 2003 0r 2004. I forget the exact date, but a search for the "first aid kit" thread will show post #1 of that thread made the date the fabric was replaced. You also may find the knobs in the trailer, in a bin somewhere, if they didn't get tossed out, I bought a pair and never installed them.
AIR#2611
Old 05-16-2008, 05:11 PM   #10
bobfowler
bobfowler's Avatar
2007 Base Camp
Images: 14
03-22-2004 - a blood sacrifice to the Aluminum Gods?
Bob Fowler
Old 05-16-2008, 05:16 PM   #11
overlander63
Images: 58
A Ford Explorer rolled end-over-end across the freeway in front of us, nearly over us, on our return trip from installing the awning fabric.
AIR#2611
Old 05-16-2008, 05:17 PM   #12
bobfowler
bobfowler's Avatar
2007 Base Camp
Images: 14
Ouch! That's never a good thing...
Bob Fowler
Old 09-06-2008, 09:52 AM   #13
utee94
Profile:  1963 26' Overlander
I'm researching awning replacement here, and if I'm reading this right, BobFowler ended up with Terry's old Argosy, is that right?
Wow, Terry, you have quite the family tree of trailers going on here! I wonder who will end up with your current trailer when you move on up to a 34' triple-axle!
Zip Dee Awning 63 Safari Awnings 8 07-17-2006 06:49 PM
Awning Heads Up!!! JaceBeck 1999 Safari 39 04-25-2006 05:31 PM
'78 Sovereign Awning Joan D'Andrea Awnings 6 01-03-2006 07:34 AM
awning replacement carmen Awnings 4 11-17-2002 09:26 AM
Awning Repair cesurman Awnings 0 08-16-2002 11:57 AM
