Old 06-17-2014, 11:21 AM   #1
3202 Ellie
boliversr's Avatar
1975 Argosy 24
milan , Michigan
Awning fabric replacement
Anyone know how to replace the canvas awning.
boliversr is offline   Reply With Quote
Old 06-17-2014, 12:56 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Who is the manufacturer of your awning?
In general, if you have a "modern" awning like A&E, Carefree, or Zip-Dee, you would first want to acquire the replacement awning (fabric), then you can extend your old awning out until you can see the slot where the fabric slides onto the roll. From here, you lock the roll, and support the assembly, if it isn't self supporting, and you remove the awning fabric by sliding it out of the tube, and out of the awning rail on the trailer. Some screws may be in place to keep it from sliding out unintentionally. Reinstallation is the reverse.
Some manufacturers require you to remove the awning tube from the arms, and at least one of the tube endcaps has to be released to remove the fabric. This is the place where things can get dangerous, as you need to make sure you are not working with a spring that is wound up with energy waiting to release on you.
Good luck
Old 06-17-2014, 01:54 PM   #3
Kevin245's Avatar
Looking at your avatar image it appears as though you have a Carefree or and A/E.
Here is a thread dealing with Carefree awnings, fabric replacement is discussed in post #12.
http://www.airforums.com/forums/f442...bly-57075.html
Regards,
Kevin
William C. Swinney
Replacing awning rod and fabric of original awning ? Mrcrowley Awnings 6 07-10-2012 06:42 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
Awning Fabric Replacement ? Davis Awnings 12 09-06-2008 09:52 AM
awning fabric replacement Kurt & Eve Awnings 2 02-19-2006 04:00 PM
Replacing awning fabric SteveS Awnings 5 01-29-2006 04:57 PM
