Cool! Glad to hear I was able to help and Tonya was as helpful to you as she was to me, I L-O-V-E good customer service! You won't be disappointed in the awning ~
So what color did you get?
Shari
Jo/Marcus, The problem with Vintage trailers and new awnings is that the awning arms do not conform to the curved sides of the trailers. I was told by my local A/S dealer that the ZipDee awning arms must be custom bent (by the owner) to the shape of the trailer. That voids any warranty that I am aware of on a new awning so used becomes more desireable. Find a used Carefree awning from a salvage yard like Colaws or Cherokee. If all the mechanical parts are serviceable you can always buy a canvas from Carefree of Colorado or have one custom fitted by a local canvas awning shop. Carefree charges about $200.00 for canvas to fit a '67 Safari. I know as I spoke with them last fall about going this route as my main awning only needs canvas. Check them out! Carefree longer makes awnings for the curved trailers but do stock some parts to repair older Carefree awnings. Their customer service folks are very knowledgeable and helpful. Hope this helps. Ed
Have fullsized ZD on each side of my 1959 Overlander. Dealer installed and work fine with no bending.
__________________ Let those who can play, let those who cann't watch....
It's Sunbrella Mediterranean/aqua stripe. Then I want to re-web a couple of vintage aluminum chairs with THIS raspberry/turquoise stripe to tie it together with my pink curtains with the white ball fringe, flamingos, etc.
“You have brains in your head. You have feet in your shoes. You can steer yourself any direction you choose.” -- Dr. Seuss
Ooooh - those are FUN colors. Can't wait to see the results!
Mel
1960 Caravel "Boris"
1967 Safari "Sparky" My Photos
Very cool! I agree, our trailers should be fun and show off our personalities ~ looks like yours is on it's way!
Shari
What about for a 68 21' Safari? Any particular awning or brand?
Your choices would be pretty much the same as Stella's, just a slightly different length.
As far as wind, I don't condone it, but we have had ours "out" when we had a sudden severe storm roll through with 90 mph gusts. It fared just fine, while several of our neighbors' awnings wound up either over the top of their trailers (torn loose), on the ground, or the tube had buckled.
Terry You repair things with tools. You fix things with a hammer.
AIR#2611
Does anybody have a photo of a zipdee on a 60s model trailer?
I don't know how far it would slant, how it would look, etc. I like how the vintage awnings come straight out and have lots of room underneath, but I also appreciate the ease of a zip-dee.
She has a rail for a rope-and-pole awning. Shari, I like your setup a lot. Seems like Stella is taller than Maxwell, somehow, and definitely has a longer rail, I think almost 12 feet, and I would love the awning to extend 9 feet.
If I did Zipdee, I'd probably hire my Airstream fixit guy to install it. He's reasonable and nice. Drilling into Stella makes me cringe. Now, to find those poles...
Here you go....new ZipDee on 1963 Overlander.
I did take some bend out of the steel arms that have the kink towards the top. I simply stuck the end of the arm under the tire gently pushed down until the angle was perfect.
It was very easy to do, and now fits really well.
One more modification was necessary....I had to drill an extra hole into the same upper arm to make the awning go higher. Otherwise, in it's highest setting, the door would rub the awning fabric really bad.
I called zipdee, and that was what they recommended. No voiding of warranties, whatsoever, btw..
I am very happy with the awning now and would recommend it to clients, no doubt.
But - for the price they charge, I do feel that the awning should fit right out of the box, without modifications whatsoever. I find it most annoying that one has to modify a $ 1500.00 awning that was custom ordered for the individual trailer. But that's just me...your opinion may vary widely....
Inland, Thanks for the tip. Yea, I am thinking of getting the 68 22'. He stated that it was a 21', but he is wrong I see. So, total length is what? How does this compare with the bambi 19' length?
