Old 12-31-2010, 02:51 PM   #1
2001 19' Bambi
Ashland , Oregon
Awning Clips
My daughter got me a very tasteful Christmas gift in the form of a string of pink flamingo lights for the Bambi.
How do I hang them? What are the best clips to use which won't damage the awning?
Can anyone tell me which are the best clips for awning lights on the Airstream? My daughter's tasteful Christmas gift of pink flamingo trailer lights need to be hung but I don't want to destroy or damage the awning. Any suggestions?
Kathleenh is offline   Reply With Quote
Old 12-31-2010, 03:11 PM   #2
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
See if you have an extra track similar to awning track on roller, you can slide tabs into track and hang anything from the grommet built into the tab, cw should have what you need.
Old 01-03-2011, 03:54 PM   #3
Kevin245's Avatar
Kathleen,
How goes it with the "Tasteful Flamingo Lights"? As Dave mentioned there are several clip types that will fit most awning systems, and I've seen some sets that come with clips.
Here are a couple from CW. But your local Wally World or RV Dealer may have something as well.
Worldwide Merchandise Company - Awning Hooks - Awning Accessories - Camping World
Jet3 Products Inc - Awning Rope Light Hooks, 10-pack - Awning Accessories - Camping World
Of course with Flamingo Lights a few old fashion clothespins would seem appropriate.
Oversized Clothespin Clips
Kevin
Eleanor Roosevelt
Old 01-03-2011, 04:03 PM   #4
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I just picked up a 24' LED rope light and wondered about the same thing.
After looking around a bit I found a bag of little plastic spring clips that seem to use stainless springs and I think are intended for laundry. They are smaller than regular clothes pins and nicer looking.
I drilled a small hole in each clip - where you would squeeze it to open - and threaded a nylon tie-wrap thru the hole and around the rope light.
I installed enough spring clips to have one about every two feet or so.
I haven't had chance to try them yet but they should work fine. They seem to have lots of holding power and I don't believe they will damage the awning in any way.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 01-03-2011, 04:19 PM   #5
2001 19' Bambi
Ashland , Oregon
Thanks, Dave, I really need to have a look at the awning to see what kind of setup we have. I don't recall a track in which to slide anything but will check.
Old 01-03-2011, 04:20 PM   #6
2001 19' Bambi
Ashland , Oregon
Brian.
You're a very creative guy, Brian. Good luck with your new hooks!
Old 01-03-2011, 05:19 PM   #7
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Plastic Spring Clips from Harbor Freight Tools
Old 01-03-2011, 05:36 PM   #8
_
almost any clothespin works (wood or plastic) fine...
downy had some primo versions for a couple of years,
these had a J hook opposite the pin so the lights could be hung on the hooks very quickly.
(they've been d/cd from the downy promo stuff 4 awhile)
the problem with almost all 'clips is they use simple spring tension which pulls loose easily...
_________
i tried a few of these 4-5 years ago and evenually purchased 2 dozen.
they work VERY very well and 'snap' closed on each end,
like some trowser suspenders.
so they can be left attached to the light string even when removed from the awning.
made with brass, therez no rust or solar decay...
they are available on am-zon and many rv supply sites...
search using the KEY TERMS noted on the packaging above...
_________
btw there is no track/slot/grove on these z-d awnings...
_________
...I installed enough spring clips to have one about every two feet or so...
while the clips and light wires might be strong enough for 2 foot spacing,
the 'skirt-edging' on the awning will simply bunch together and not maintain an even distribution of the lights/wires...
it depends SOME on how much each fixture weighs and how large the covers (swinging in the wind) are but generally,
the clips will need to be spaced 4-12 inches apart IF hanging from the edging...
IF one installs brass grommets in the skirt OR rivets into the poll greater spacing can work.
cheers
2air'
Old 01-03-2011, 06:41 PM   #9
tpi
Trabuco Canyon , California
Amazon.com: Tarp Clips, 2pk: Sports & Outdoors
I use tarp clips like these. They're shut by ratchet mechanism, they don't rely on a spring. They're also handy for hanging the lights in tree. They are sufficiently strong for my large prismatic globe lights.
tpi is offline   Reply With Quote
Old 01-03-2011, 07:01 PM   #10
2010 25' FB Flying Cloud
Davenport , Iowa
I use "badge clips" these are purchased at Wally in the stationary dept. They have a clip as 2-air shows, but on the one end there is a plastic strap with snap on it. I use these with the string type of lights,ie AS trailers, flamingos and palm trees; too small for the rope lights. The plastic clips work better there and don't rust.
Airtandem is online now   Reply With Quote
Old 01-03-2011, 07:48 PM   #11
TAC OH-17
runningbarre's Avatar
1994 34' Limited
Upper Sandusky , Ohio
we also use the badge clips, they are cheap and work very well
Grumpy old man
runningbarre is offline   Reply With Quote
Old 01-04-2011, 12:53 PM   #12
2001 19' Bambi
Ashland , Oregon
Lots of great suggestions. My concern is clipping something to the Airstream awning which won't cause damage to it. I'll have a look at some of the hooks and gismos suggested on here. Much appreciated!
Old 01-04-2011, 03:48 PM   #13
Jezibels's Avatar
1966 24' Tradewind
Chicago , Illinois
Awning Clips
Just stumbled on these today! $2
1/2 Inch Library Clips - Clearance - by Stampin' Up!
Happy Trails!
Jezibels is offline   Reply With Quote
Old 03-12-2011, 10:29 AM   #14
2001 19' Bambi
Ashland , Oregon
Despite all the wonderful suggestions, I am no closer to hanging my flamingo lights. I hesitate to attach a clip directly to the awning material for fear it will rip/damage it. We don't have a track where we can slide in awning hooks. I wish the Airstream Accessory Store had something we could use but they don't. Still a bit frustrated.
New Owner sgray Member Introductions 9 01-02-2011 08:16 AM
Another lesson learned RLS On The Road... 2 01-01-2011 09:57 PM
