Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 06-21-2004, 06:52 PM   #1
Profile:
Awning bracket fastening
Re: '96 Excella. The front mechanism, curb side is quite difficult to operate. It appears the bracket near the top, which holds the unit down when retracted/traveling, has been lowered 1/2", causing a bind. What is behind the skin to fasten to? If the original screw holes were stripped, causing someone to lower the bracket, how could the original holes be reused? Larger screws, fill the holes with "liquid metal" of some type and see if the new fasteners will hold? Thoughts and ideas appreciated.
jackt is offline   Reply With Quote
Old 06-26-2004, 01:18 PM   #2
RichardT's Avatar
Profile:
Liquid metel will not work. Either find an anchor at the home depot (there is a whole section in hardware near the drywall anchors , masonry anchors) to screw into or make a plate to attach that has new holes in it for the screws, you can make this out of aluminum and rivit on, if you do it nicely it will hardley be noticable.
RichardT is online now   Reply With Quote
'78 Sovereign Awning Joan D'Andrea Awnings 6 01-03-2006 07:34 AM
Ground bracket solution for awning yukionna Awnings 3 10-05-2003 09:09 AM
Awning Bracket Question? JoeW Awnings 13 09-17-2003 11:24 AM
awning bracket manley Awnings 2 08-22-2002 06:16 PM
Awning Repair cesurman Awnings 0 08-16-2002 11:57 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
