Old 08-15-2008, 11:42 AM   #1
jagcb750's Avatar
1986 30' Airstream 300
B , Louisiana
awning bar
Is there a solid metal bar that runs down the middle of the rolled up awning? I read the post about the main awning arm bent, but didn't think the poster was talking about the same thing. I have a 345 airstream rv and the mechanism that the awning rolls up on is severely bent. The awning I'm referring to is, of course, the biggest one above the door. Do you have to remove the awning in order to bend this back? Where would I need to begin?
Oh, it is a Zip Dee awning.
jagcb750 is offline   Reply With Quote
Old 08-15-2008, 02:01 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Here is the instruction page for that proceedure. Hope it helps...
Awnings By ZipDee
Richard
Old 08-16-2008, 06:52 AM   #3
jagcb750's Avatar
B , Louisiana
Thanks AZFlycaster! This is exactly what i was talking about. I just hope that I don't have a kink in the roller tube. Wish me luck.
Old 08-16-2008, 10:26 AM   #4
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
While we`re on the roller tube,is it possible to remove the springs and cut off a tube? thanks Dave
easyride is offline   Reply With Quote
Old 08-16-2008, 10:37 AM   #5
2002 25' Safari
Dewey , Arizona
Images: 62
I know that it has been done. Brad (flyfshr) did just that on his Trade Wind. I would think it would be easier to adjust the non spring end of the roller and not mess with the spring end. The arms of the awning should mount to vertical ribs in the trailer. The length of the roller will be based upon those mounting points.
Here is what the roller looks like:
Awnings By ZipDee
Richard
Old 08-16-2008, 11:14 AM   #6
easyride's Avatar
1977 27' Overlander
Naples , Florida
Awnings By ZipDee
My arms are mounted,the tube kinda got bent ,well kinked,during a surprise rain storm,never leave home without dropping a corner. Thanks for info I`ll try it. Dave
Old 08-16-2008, 11:32 AM   #7
ZIP DEE ONLY
The spring is in the rear of the awning roller tube, ONLY.
DO NOT do anything with the awning until you release the tension on the spring. That's done by carefully unwinding it using the rear arm as a lever.
It takes two people to do that, in order to be safe.
Extend the awning completely. Set up the front arm as usual.
Release the rear arm where it attaches to the near bottom of the coach. Trailers and motorhomes both use the same procedure.
Stand rearward of the arm, holding the rear arm tightly, unwind the spring by turning the arm counter clockwise, slowly but again carefully.
If you allow the arm to get away from you, it will rapidly spin and cannot only maim a person, but if it hits you on the head, it could kill you.
That's the reason for using two people. One to do the unwinding and the other to hold the tube at the rear, since it will not have any mechanical support.
Once the tension has been release, you can tinker with the awning as you wish.
If you wish to shorten the awning, cut it at the front, never the rear.
You must count the number of turns as you unwind the awning, so that you can put the same amount back in, when your reinstalling the awning.
There is a formula of the number of turns you use, and I will post that this Monday.
Dealing with a bent awning tube varies from easy to near impossible, depending on the approach you take. Again, reshaping the tube, is a two person job.
Old 08-16-2008, 02:04 PM   #8
richinny's Avatar
2011 34' Classic
Awnings By ZipDee
Ricky
Awning Rail Seal? & Awning Wardinbb Awnings 3 08-06-2013 02:37 PM
what's up with the advertising bar? urbanfood Off Topic Forum 12 12-24-2007 08:42 AM
Torsion Bar vs Sway Bar acrane Hitches, Couplers & Balls 9 07-31-2006 06:11 AM
Awning Aluminum Extesion bar. Devoman Awnings 10 05-24-2006 01:04 PM
Is the roadside awning option for a 28' Classic really just a single 19' awning? Dave Jenkins Our Community 1 08-17-2003 03:07 PM
