Old 07-11-2011, 02:20 PM   #15
Originally Posted by Jcashcollect View Post
Man, I wish I would have read this thread first. Just bought and paid for a 16' A&E awning. I went though a local RV dealer. Only reason was because shipping other items from the US has been a PITA. Sorry Andy, really wanted to keep going through you. Am I gonna kick myself if I go through the trouble of installing this thing?
Sorry, but it was your choice.
Old 07-24-2011, 12:37 PM   #16
Jcashcollect's Avatar
1978 31' Excella 500
Kelowna , British Columbia
Hey guys, here is an update. The awning has been installed. The instructions weren't that clear, and it's obvious that they took the parts for a straight armed awning and just bent the main arms. It would not install properly until we cut the small arms off. They were too long. I mounted the bottom brackets to the molding that runs along the bottom, which also has the metal base of the floor. There just didn't seem to be anything solid below that or the arm length probably would have been fine. The arms were also stuck together and had to be worked in order for all of the parts to slide properly. That being said it looks pretty good when finished. Next time I will order the zipdee, just for the ease of install.
Thanks again to this forum for all of the help, and links to great resources. We have done just about everything imaginable to this trailer. Next we polish
Jcashcollect is offline   Reply With Quote
Old 07-24-2011, 05:20 PM   #17
Since your going to polish the trailer, you will get more awning experience.
Remove the awning, "BEFORE" you start to polish.
If you don't, that black gooey stuff from the polishing process, will get all over the awning.
Old 07-30-2011, 03:13 PM   #18
bilby05
bilby05's Avatar
1962 24' Tradewind
1962 24' Tradewind
Canyon , Texas
This thread fits right in with info that I needed. A couple of more quick questions. Where is the best place to purchase the appropriate curved arms, and other hardware, to fit our '69 31 foot Sovereign. And how long (front to rear) should the awning be for optimal coverage, and vintage appropriateness. Like everything else on our AS should be, but isn't.
thanks, bill b.
1962 Airstream Tradewind
2001 Ford 7.3 Diesel
bilby05 is offline   Reply With Quote
Old 07-30-2011, 04:11 PM   #19
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
If you contact Zip Dee they can tell you the exact size awning for your AS.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 07-30-2011, 04:31 PM   #20
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Awning Advice
Another advantage of the Zip Dee is the support that the manufacturer offers for all of its products regardless of age that have been installed on Airstreams. A & E/Dometic essentially told me that I was on my own regarding repair parts in 1999 so I junked the A & E awning on my Overlander and installed a new Zip Dee and couldn't be happier with its quality and performance.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 07-30-2011, 06:10 PM   #21
thanks, bill b.
You need a 20 foot 11 1/4 inch Zip Dee awning for a 31 foot Airstream trailer.
The most popular color is # 4755, Pacific Blue Fancy.
Any hints, tips, and/or advice... HansenClan Awnings 5 07-04-2011 03:57 PM
Using your awning sbcohn On The Road... 29 06-14-2011 05:14 PM
First time buyer seeking advice Broccoli Buyer Guidelines 14 04-14-2011 11:24 PM
Awning Hooks Kathleenh 1997 - 2004 Bambi 3 03-14-2011 11:38 AM
