Old 03-25-2019, 09:05 PM   #1
Mollysdad's Avatar
Awning advice.
This falls into the "What would you do" category.
My awning and I have never made friends. Partly my fault, but not this time.
Here's the problem. When I roll up the awning, no matter if I do a zig-zag on the tape or wind it to the front or rear, it always ends the same. The front awning clamp (the thing with the wheel) aligns perfectly, while the rear one is about 5/8" too high. In order to get the wheel and it's bolt to latch I need to push up on the roller with a pole.
So here's my ideas.
1. It's under warranty, let the dealer fix it----except I'm paranoid about a leak because he'll just move the clamp into new holes.
2. Buy the lower bracket arm from Zipdee, (It's called the lower hinge bar) it's the piece from the trailer to the arm.
About a foot long. Then, plug the holes and drill new holes 5/8" farther up, therefore raising the arm and roller when retracted. The problem with this is the travel lock won't align without pulling. (It's called the travel latch hook) It doesn't hook now without pulling on it.
It's an issue not covered in the videos, "When things don't work like they're supposed to"
I don't use the awning much, but it's never been right. I used to attribute it to the trailer being out of level, but I've experimented many, many times while on a level concrete parking lot, and the result is always the same.
I'm open to creative suggestions.
Old 03-25-2019, 09:40 PM   #2
aftermath's Avatar
Spokane , Washington
Sorry, no creativity here. I would take it back and have them fix it. Share your concerns about possible leaks and listen to what they say. Do you trust these guys?
And, you second option still requires removing a bracket and redriling holes. What is the diff?
aftermath is offline   Reply With Quote
Old 03-26-2019, 07:39 AM   #3
Mollysdad's Avatar
The problem with any dealer is you never talk to the tech who will actually work on it. You talk to a service advisor, who fills out a work order and the tech may or may not think your concerns are worth his attention. Ideally, I'd like to talk to the tech and ask his advice. He might say, "I do this all the time, don't worry!"
No.
The second option has me replacing one of the arm parts with one I modified making it slightly longer, no drilling into the Airstream skin.
I didn't make myself clear, I guess.
Option 1: Move this clamp screwed to the roof.
Or, Option 2: Make this a bit longer by redrilling new upper holes.
Pardon my yakking, but it looks like moving the bracket (the correct solution since the travel hook will then align) will still have the old holes under the bracket, and it has three screws, I thought it was one screw and two rivets. I need to see it again. Just because Zipdee designed it with three screws doesn't mean Airstream actually did it that way.
Old 03-26-2019, 07:43 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
For small adjustments, the bend in the arm cam be changed (bent) to extend the arm slightly. Contact ZipDee with your concern and find out what they say.
Richard
Old 03-26-2019, 09:10 AM   #5
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Originally Posted by Mollysdad View Post
...The front awning clamp (the thing with the wheel) aligns perfectly, while the rear one is about 5/8" too high. In order to get the wheel and it's bolt to latch I need to push up on the roller with a pole.
If I understand, you need to raise the aft end of the awning so the wheel latch will go into the bracket.
We have a similar situation (if I read correctly) and I found that pushing the arm assembly closer to the side of the airstream helps lift it up and align it with the wheel assembly. The pelican hook lock also then aligns properly and is easy to fasten. (However, I have had to use some thread locker on the pelican hook threads as they were always getting loose.)
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 03-26-2019, 09:14 AM   #6
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Are you going to have to weld up the existing holes in the arm. Or is the move sufficently far? I would not get the dealer to drill new holes in the trailer skin. I would try the arm approach or have a couple of beers and just live with it. It sounds like you can close it up fine with extra effort.
Old 03-26-2019, 10:10 AM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
So here's my ideas.
Ours was similar, the rear arm was not plumb, (to far back), forcing the awning to roll up cockeyed pushing the front high, wheel off about 2"👎
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 03-31-2019, 11:52 AM   #8
Mollysdad's Avatar
Weld? No. I was thinking of inserting a bolt snugly in the existing hole 5/16"? and cutting it off flush. Being dissimilar metals, it would weld itself over time.
The only way, looking at the diagram above is that part #12 (the upper clamp) looks like it would still cover the existing holes.
Yes with great effort. (and a boat hook)
That works in the front but in the back it's like it's already under tension and doesn't want to push in.
All good ideas! Thanks, keep them coming!
Old 03-31-2019, 12:43 PM   #9
What if you try the rear awning arm first - shouldn’t be under tension then.
Ray B.
Old 03-31-2019, 02:07 PM   #10
Central , Mississippi
You can download the installation instructions and use them to measure if anything is installed wrong. The first step is to measure down from the awning rail a given distance to the lower brackets. Then the upper brackets are mounted directly above the lower ones with the main arms setting the height. You might be able to figure out if one of the components was installed in the wrong spot. When facing an awning, the left arm is the one with the spring... it will spin out of control if you take it loose and aren't very careful!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Awning Rail Seal? & Awning Wardinbb Awnings 3 08-06-2013 02:37 PM
Replacing awning rod and fabric of original awning ? Mrcrowley Awnings 6 07-10-2012 06:42 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
Awning or no awning? 2wheelin Awnings 11 04-06-2010 05:38 AM
Is the roadside awning option for a 28' Classic really just a single 19' awning? Dave Jenkins Our Community 1 08-17-2003 03:07 PM
