Old 04-26-2009, 02:40 PM   #1
mok
MOK
North Providence , Rhode Island
Awning
I have difficulty putting my awning away. The extender arms do not want to fully collapse past the last setting. Any ideas?
mok is offline   Reply With Quote
Old 04-26-2009, 02:42 PM   #2
wolverine's Avatar
2005 31' Classic
Sunrise Beach , Missouri
Try a shot of silicone spray lubricant--that should free them up.
wolverine is offline   Reply With Quote
Old 04-26-2009, 03:50 PM   #3
eikel1we's Avatar
1975 25' Tradewind
, Michigan
Send a message via AIM to eikel1we
Rivet Check Your Nuts
There may be grit in the tubes. We used a cleaning solution (formula 409?) and flushed the tubes with the hose. After the tubes dried the arm going into the tube was siliconed. It really helped. Airstream also has handles that attach to the arm so you can push them outward from the tube.
**Now to those nuts! Be sure to check the acorn nuts on the awning every so often. After this warning a couple of years ago we found some loose and one missing. It would be costly and dangerous to loose an awning on the highway.
suz
sue and ike
'75 Tradewind - 25'
"Cupcake" air-912
2004 GMC Yukon XL 2500
Michigan - "middle of the mitt"
eikel1we is offline   Reply With Quote
Old 04-27-2009, 04:19 AM   #4
mok
MOK
Awning
I took the tubes apart and cleaned them - it appears that was not the problem. The tubes appear slightly curved in the area of the detents nearest the 30 degree bend. Should they be?
Old 04-27-2009, 06:53 AM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Zip-Dee
The Zip-Dee web site is great for info like this. They have an 800 number too. You really speak with REAL people and they are extremely helpful. I don't have any bends in my awning arms.
Old 04-27-2009, 07:25 AM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
If it is the solid aluminum piece that slides into the hollow square tube. It should be straight, except for the single bend. If it is curved, it has been bent, and is binding inside the hollow square tube.
Awning Rail Seal? & Awning Wardinbb Awnings 3 08-06-2013 02:37 PM
Replacing awning rod and fabric of original awning ? Mrcrowley Awnings 6 07-10-2012 06:42 PM
Awning tracker Awnings 5 03-14-2006 10:11 AM
Is the roadside awning option for a 28' Classic really just a single 19' awning? Dave Jenkins Our Community 1 08-17-2003 03:07 PM
