Old 05-07-2015, 06:10 PM   #1
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Awnbrella
Have any of you folks had experience with "Awnbrella"? It's an interesting product that uses an arched aluminum "rafter" that is installed between the sidewall of the AS, and the awning roller.
When the awning is extended and these are installed, it creates a gentle arch in the awning so rain water can't "pool".......yes, I know the procedure of "tipping" the one end of the awning a coupe notches below the other end. But this look's like it'll do the job better, at at the same time give more clearance so the entrance door doesn't contact the awning. Those cute little rollers on the top of the door eventually wear the awning.
Comments are appreciated.
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 05-07-2015, 06:16 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have a center rafter that has never been installer. Never seen a reason to use. Easy to tip one end and get good run off.
MICHAEL
Old 05-07-2015, 06:18 PM   #3
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
If it's anything like the center rafter on the ZipDee awning on our Avion, it's well worth having.
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
