Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 07-03-2008, 07:51 AM   #1
cushmangirl
Profile:  1976 Argosy 22
Waynesville , Ohio
Argosy Awning
I have a question about our 1976 Argosy awning. It currently has the A & E Systems 5000 Model. We need to put a new awning on, but we need to make corrections to the hardware. The hardware works as far as opening the awning and setting it up, but taking it down is were we have the problem. It does not want to roll up correctly. Sometimes it rolls correctly on one side, but the other side has extra awning hanging out. Any suggestions on repairing the hardware, and where would be the best place to purchase (cost) the awning? Is it possible to purchase an awning from Ebay or any of the other sites like Ebay? Any suggestions would be helpful.
cushmangirl is offline   Reply With Quote
Old 07-03-2008, 08:57 AM   #2
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Welcome to the Forums!
These awnings have an internal torsion spring in one (or both) ends, depending on the length of the roller tube. It sounds like one of the torsions is bad and in need of replacement, or the roller mechanism on the bad side is binding.
Either situation requires you to remove the end caps for inspection. This operation involves removing the lower rafter arms from the roller tube and unwinding the spring.
BE VERY CAREFUL HERE!!!!!!!!! There is a definite procedure to follow and serious injury can result if you don't do it correctly.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 07-03-2008, 11:09 AM   #3
Pfredd
Pfredd's Avatar
Profile:  1978 Argosy Minuet 6.7 Metre
1977 31' Sovereign
1977 Argosy 24
Cincinnati , Ohio
If you end up deciding to replace your awning then I would go for a Zip-Dee.
Those E&E awnings just don't look right on an Airstream or Argosy....
Visit my web site for Airstream Photos, Projects & Blog
Pfredd is offline   Reply With Quote
Old 07-03-2008, 12:05 PM   #4
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
For a new awning the only choice you have is a vintage awning or a Zipdee. The vintage awnings have to be manually installed and taken off every time you setup, but they look great and the price is a fraction of a Zipdee. I have a Zipdee that I installed a few years ago and think it is the best. They are very well built, but will cost you over a thousand dollars. There are a couple of members on the forums that are Zipdee dealers and do offer a discount.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 07-03-2008, 02:13 PM   #5
till
till's Avatar
Profile:  1967 26' Overlander
1968 26' Overlander
Lisle , Illinois
Images: 108
The older A&E awnings are not that bad.
Just about any place can work in the awning. Also you can have just the roller replaced. Also the material if you want.
Tedd Ill
AIR#3788, WBCCI#4028
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 07-03-2008, 06:50 PM   #6
3Ms75Argosy
3Ms75Argosy's Avatar
Profile:  1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
I say stick with the A&E... you can buy a replacement roller for much cheaper than a Zip Dee.. but I'd call A&E themselves to see if they have replacement parts for your current one first. IMHO, the zip's are a bit more fragile than the A&E...
Search A&E on the forums, there's photos of the A&E installation manual which will tell you how to disemble the roller.
Marc
Old 07-03-2008, 06:58 PM   #7
3Ms75Argosy
1963 24' Tradewind
Here you go..
I think Carefree was bought out by A&E somewhere down the road... or vs. versa... anyhow, here's the manual.
http://www.airforums.com/photos/show...&searchid=6622
Good luck!
Marc
Old 07-03-2008, 10:34 PM   #8
lewster
Commercial Vendor
lewster's Avatar
Good luck!
Marc
Actually, Carefree was purchased by a private concern and is now part of a much larger industrial group. They also make and sell anchor windlass systems for yachts. They have a very nice factory in Colorado (duh!) that I have been thru....very impressive!
A & E Systems was purchased a while ago by Dometic, and is now a fully integrated part of their company. Their manufacturing facility is in LaGrange, Indiana.
If you are wondering where I get this info from.......I represent both companies, as well as Zip-Dee and Girard Systems (all awning manufacturers)
AIR # 10325
Awning tracker Awnings 5 03-14-2006 10:11 AM
How to ship a argosy? and loaded weight of a 22' argosy outerbanksdeb On The Road... 13 01-21-2005 01:55 PM
Awning Rail Seal? & Awning Wardinbb Awnings 1 09-23-2004 09:57 AM
Awning pumpkin For Sale & Wanted 5 07-11-2004 04:15 PM
Is the roadside awning option for a 28' Classic really just a single 19' awning? Dave Jenkins Our Community 1 08-17-2003 03:07 PM
