Old 06-22-2015, 10:23 AM   #1
1978 31' Sovereign
Decatur , Georgia
Any Special Storage Requirements for ZipDee Awning over Winter
I have just put on a new ZipDee awning on our newly acquired 1978 Sovereign. After a rain, when I open the awning there is some water run-off that has accumulated (not puddling, just water in aluminum roll and on ends of awning). I am concerned when I close up the trailer for the winter that I will get moisture accumulation and mildew over the winter. Trailer is in Canada all year and only in use from June to September. Any feedback is greatly appreciated.
wabislander is offline   Reply With Quote
Old 06-22-2015, 11:39 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
No
The awing will pump moisture from the ends do the temperature changes but that will not cause a problem.
2004 Excursion 4x4
Old 06-22-2015, 01:20 PM   #3
1974 Argosy 20
Kooskia , Idaho
The Zip Dee Sunbrella material will not mildew. One of the beautiful things about the ZD awnings. If it is dirty from being extended for a long time, clean it prior to putting the rig away as some of the things that fall on the material can become food for mildew, but even that will wash off when you go to clean it, if it happens.
The only thing that a has ever happened to my Zip Dee fabric was that once ants got into it and built a nest when rolled up, and chewed some small holes in the material.
Old 06-22-2015, 01:33 PM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
The threads in mine started to rot....Matter of fact, I just got it back from the upholstery shop from being restitched and am putting it on right now.
CRH is offline   Reply With Quote
Old 06-22-2015, 10:38 PM   #5
1978 31' Sovereign
Decatur , Georgia
Thanks for all the feedback.
Old 06-23-2015, 03:53 PM   #6
1967 26' Overlander
Spartanburg , South Carolina
Would you mind saying how much your new awning cost to purchase & install?
Jacob D is offline   Reply With Quote
Old 06-23-2015, 10:42 PM   #7
1978 31' Sovereign
Decatur , Georgia
I don't have the exact figures so these are ballpark.
Awning: around $1,500
Mounting hardware: around $600 (this is all of the necessary hardware, arms, boldts, screws)
Mounting track: around $60
Olympic Rivets: don't recall but there are around 4 rivets per foot on the mounting strip
Shipping to dealer: around $200
Because of the location of my trailer, I picked up the awning at the dealer and installed it myself. The directions were not great but I was able to figure it out. The most difficult part was attaching the awning to the mounting strip. If was a 4 person job (2 holding the awning arms, one on the trailer roof attaching and one feeding the mounting piece.
DEALER
Got it from Out of Doors Mart in North Carolina. They were very helpful with all of my questions.
Old 06-23-2015, 11:13 PM   #8
CRH
1995 25' Excella
xxxxx , xxxxxx
What did "awning" include for $1500?
Old 06-25-2015, 07:44 AM   #9
1978 31' Sovereign
Decatur , Georgia
The awning was (pardon my lack of mechanical ability) the awning itself mounted on the support rod and aluminum covering that wraps the awning when retracted. The main rod contained all of the needed spring assembly. Out of the box/tube, the awning just had the connecting bolts extending out from each end that you then attached the ZipDee logo'd hardware from the awning to the arms mounting to the trailer.
The ZipDee logo'd attachment hardware and all other mounting arms and brackets were part of the hardware kit and not included with the awning.
Hope that helps.
Old 06-25-2015, 08:00 AM   #10
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
I have the same coach. My Zip Dee is original and in near perfect condition. Make sure that it is bone dry before you roll it up for extended periods. If you should happen to get a little rain and have to move, remember to extend it when you get home, brush off any leaves and let it thoroughly dry. I leave my awning "as-is" with no waterproofing. It would only break down over time and cause problems.
NavyCorpsman is offline   Reply With Quote
Old 07-11-2015, 06:49 PM   #11
1997 34' Limited
1994 33' Land Yacht
Lexington Park , Maryland
Images: 20
Ants
Sadly, ants have chewed several holes in my rolled up main awning. Disgusted...
Tinkstream is offline   Reply With Quote
ZipDee Awning Spring Stop Rivets Question 3blessed Awnings 0 06-16-2010 08:43 AM
Airstream ZipDee window awning for '65 Caravel 76sovereign 1965 Caravel 1 08-03-2008 06:40 PM
RV storage requirements boondockdad Insurance & Claims 4 11-07-2007 11:41 AM
How much should a 16ft ZipDee Awning cost? Silverfly Commercial Listings 3 07-13-2004 05:20 AM
