Yes, I made a new awning for the zip dee hardware on our '71 Tradewind.
The details are in my
blog here
We had to replace the channel at the top end. We bought some aluminum stock from Sailrite. If I recall correctly, that's where we bought the sunbrella fabric as well.
I had access to a walking foot industrial sewing machine and I'd say that's a pretty necessary piece of equipment. On a home sewing machine, the fabric is only moved by the feet that grab the underside of the fabric. This means that the bottom layer often moves faster than the top and the bottom layer gets puckered with respect to the top layer. The walking foot machine grabs both layers at the same time so the ends of the seams matched up, even after 9 feet of stitching.
The one thing I would do differently is not assume any stretch in the sunbrella at all. We made it a tad short on the length from top to tube, thinking that would make a nice, taut awning. The awning doesn't sag at all, but a side result is that there is barely enough awning fabric to allow us to pull the arms out into full lock. Maybe I need to do more pushups.
Another thing that I didn't fully allow for is the amount of material taken up by the seams. I tried to match the pattern exactly for the seams that joined the three panels at the sides. Due to extra take-up in the seams, the stripes where the seams run are slightly narrower than their counterparts without seams. This wouldn't have been an issue at all, except that it would have made the curves at the top of those scallops shorter. I solved that by flattening the top of each scallop so they are all the same height anyway. The standard awnings don't have scallops at all, so that wouldn't make a bit of difference for those.
I bought a double-sided fabric tape to hold the seams since Sunbrella is too dense for pins and pins would distort the seam anyway.
I used a double fold under for the side seams and a matching bias tape (also Sunbrella) along the scallops. I would go more carefully along the scallops next time. No one else notices the places where the seam ran off the edge of the fabric underneath, but I know the holes are there.
Long story short, with the right tools, it's very doable. And even if you try for extra details and it isn't perfect, it still comes out great. We love having a functional awning again.
