Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 09-05-2008, 05:34 PM   #1
Kevin245's Avatar
Acrylic vs. Vinyl Replacement Fabric
I am looking to replace the fabric on my old Carefree awning. Does anyone here know the pros/cons of acrylic vs. vinyl fabrics. Also does anyone have experience with RVAwningsonline.com?
Kevin
William C. Swinney
Old 09-05-2008, 08:15 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
You may want to read this article.
What is Acrylic Fabric?
And look at this
FABRICS & VINYLS - sunbrella
Old 09-09-2008, 03:35 PM   #3
Silverhobby's Avatar
Greeeneville , Tennessee
Acrylic fabric is a bit more loose weave and it "breathes". It is cooler to be under on a hot day than vinyl is. Just my opinion.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 09-09-2008, 06:05 PM   #4
Naples , Florida
Acrylic will outlast vinyl by a long shot.
Vinyl is after all....plastic....... while the acrylic is woven fabric. Much more forgiving and durable.
I don't do any replacement vinyl....only Sunbrella acrylics. The cost difference is really minimal, it's much easier to handle, and looks great when compared to any vinyl.............YMMV!
lewster
Old 09-09-2008, 06:32 PM   #5
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
The link below is a good place to buy Sunbrella, they also sell a knock off of sunbrella which is just as good. I use yards and yards on my sailboat.
Upholstery Supply & Marine Fabric Superstore
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 09-14-2008, 05:34 PM   #6
Kristi Foster's Avatar
Jonesboro , Georgia
Images: 33
Hi,
Sunbrella acrylic is mildew,fade,rot,rain,UV, and tear resitant plus breathable. The colors are just as vivid underneath as they are on top. It does have a tendancy to fray, so all the seams will need to be covered or enclosed. The marine 9.25 ounce is the type for awnings. It is 46" or 60" wide and stiffer than the 54" which is for furniture. I use it on a regular basis to make Vintage Look Awnings. I hope this information is helpful. KF
Kristi Foster is offline   Reply With Quote
Old 09-14-2008, 06:58 PM   #7
Naples , Florida
Originally Posted by Kristi Foste View Post
Hi,................'snip'..........
. It does have a tendancy to fray, so all the seams will need to be covered or enclosed................'snip'............... KF
Kristi,
You should use a hot knife when cutting acrylic fabrics. This seals the edges and prevents fray from happening. The major awning manufacturers are now using ultrasonic cutting machines that cut and seal the edges (similar process) at the same time.
lewster
Old 09-14-2008, 10:48 PM   #8
Jonesboro , Georgia
Images: 33
Acrylic Fabric
Hi,
I have seen the cutters that you are speaking of, they are awsome but quite pricey. Since making awnings is just a hobby for me, I have learned to deal with the fraying by enclosing the seams and covering or binding the raw edges. It works for me. KF
Old 09-15-2008, 12:14 AM   #9
Revcon Owner
daveinet's Avatar
Chicago area , Illinois
Originally Posted by lewster View Post
Kristi,
The reason they go with Ultrasonics is because the Ultrasonic knifes do not gum up like a heated knife does. Also, because the knife is vibrating, it tends to self sharpen till you loose enough metal that it looses tuning. 5K will get you a knew machine, but I seen ones go on Ebay for a couple hundred bucks. You'd have to buy the knife and possibly the hand probe separately.
daveinet is offline   Reply With Quote
Old 09-15-2008, 05:20 AM   #10
Jonesboro , Georgia
Images: 33
Hotknife
The Engel Hotknife is a great tool for cutting synthetic fabrics, webbing, rope—things that would ravel when cut with scissors. The controlled heat melts synthetics to provide a sealed edge or end. And it is fast and safe. Trigger operated it heats up in 6 or 8 seconds and provides a light to illuminate the area being cut. A cool, comfortable hand grip and a rapid cool down assure safety in use. Blade Sold Separately
Two cutting blades are available for the Engel (neither are included when purchasing the tool - you must buy one or both separately). The 100R Blade is recommended for cutting lengths of fabric and line. The HSO Blade is designed for more precise cutting—sharp corners and detail work. Also available is a Cutting Foot that can be used with the 100R Blade to eliminate the need for a special cutting surface.
Built to last for years the Engel Professional Hot Knife draws 70 watts.
For a cleaner cut when using a hot knife, cut on a hard surface—glass, mirror, Formica.
To see the Professional Hot Knife in action watch the videos below: If you do not see graphics and video, your web browser is not equipped to show Java rich media. Please visit http://www.clipstream.com/help/visitorhelp.shtml to learn how to enable your client for rich media.
Old 11-01-2008, 06:11 AM   #11
Kevin245's Avatar
Follow Up...Good Service
Kevin
I ended up ordering two Acrylic awnings (one for me, one for Dad). Anyway the folks at rvawningsonline were great to deal with. They contacted me twice concerning my order and the units were received within two weeks of the order date.
Installed the first one Thursday with no problems. The alumagaurd looks great on it too.
William C. Swinney
Awning Fabric Replacement ? Davis Awnings 12 09-06-2008 09:52 AM
Replacement exterior vinyl striping Padraic All Argosy Trailers 20 12-01-2006 12:59 PM
Shower vinyl wall covering replacement. capehoorn Sinks, Showers & Toilets 0 05-19-2006 02:03 PM
awning fabric replacement Kurt & Eve Awnings 2 02-19-2006 04:00 PM
Acrylic window care Janet H All Argosy Trailers 4 06-29-2004 11:54 AM
