Old 01-16-2008, 05:19 PM   #1
higgy116's Avatar
1972 29' Ambassador
Edgewater , Florida
Question A&E Imperial 8000 awning help?
Hi All,
I was wondering if anyone could help me with some information about my A&E Imperial 8000 awning on my 72 ambassador. I started working on it and think I am missing some parts from the adjustable heigth bars. Everything seems to work ok as far as I can tell however I can't figure out how you lock the arms at any of the holes when I raise the awning? am I missing something or doing something wrong? I see where it is supposed to lock but it does not.
higgy116 is offline   Reply With Quote
Old 01-17-2008, 12:46 PM   #2
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Higgy,
I had that type of awning and one day one of the lifting handles stopped working. The ratchet device broke for some reason or other. So what I ended up doing was getting a hitch pin and stuck it in the proper hole whenever I needed it.
A&E may have a replacement part, but that worked well enough for me.
Pat
pmclemore is offline   Reply With Quote
Old 01-18-2008, 08:13 AM   #3
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Pat, I think the part you may need is a spring clip and A & E makes replacements for their awnings. Check with your awning dealer.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 01-18-2008, 08:20 AM   #4
higgy116's Avatar
1972 29' Ambassador
Edgewater , Florida
Thanks but...
Thanks for you replys, and I thought of that but was wondering if there would be a problem with wind lifting the awning if a big wind came up, and would that hurt anything? if I use a pin in one of the holes nothing will keep it from lifting, what do you think.
Old 01-18-2008, 09:47 AM   #5
Ready-to-Travel
pmclemore's Avatar
I'd never leave it out for a big wind to take it. And do whatever it took to not be surprised by one.
Pat
Old 01-18-2008, 10:35 AM   #6
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Pat
I also used a pin in a previous trailer awning with no problems. Wind is always a consideration whether you have the original parts or a pin.
Dave
Fyrzowt is offline   Reply With Quote
Awning Rail Seal? & Awning Wardinbb Awnings 3 08-06-2013 02:37 PM
Is an '04 worth $8000? kaman 2004 Safari 9 07-03-2007 09:24 AM
Twink hitting 8000 posts? CanoeStream Off Topic Forum 66 05-06-2007 07:25 PM
A & E Awning suprtrker Awnings 3 05-23-2004 01:44 PM
a& E awning problem help art Awnings 4 09-11-2003 07:10 PM
