Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 10-16-2009, 11:48 PM   #1
Safari64's Avatar
Profile:  1964 22' Safari
Eagle River , Alaska
A&E curved arm attachment
I have an A&E awning on ’64 Safari that PO had installed at Camping World. OK fine.
The bottom brackets for the arms are held to trailer with ¼” x 3” lag screws…through banana wrap skin into what?? The frame?
Is this really how they are supposed to be attached? Lag screws? No bolt/plate/spacer/nut?
After 16K travel miles (including both ways Alaskan Highway) one screw holding front arm bottom bracket to body sheared the head, the other pulled out, the arm flopped around before I spotted it and broke jalousie window.
Can’t see a way to attach any firmer without pulling banana wrap panel (that’s why they used lag screws, duh).
New A&E kits come with the lag screws.
How have others attached awning bottom brackets to Airstream trailer bodies?
Thanks for help
Safari64 is offline   Reply With Quote
Old 10-17-2009, 04:22 AM   #2
Profile:  1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
The bracket should attach at or just above floor level where the lag screws go either into the plywood floor or the bottom rail that sits on the floor. I installed mine this way and have had no problems in 6 years
If attachedslightly higher than this a small access hole could be cut in the inside wall to allow a back up plate or big washers and then the hole covered with a blank electrical wall plate
http://defendwally.org/
Rick Davis 1602 TAC TN-2 K8DOC
PP VAC 2002-03
61 tradewind, 70 Globetrotter
69 Ambassador 64 Overlander
Old 10-17-2009, 07:47 AM   #3
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Somewhere , Over the Rainbow
The newer trailers use Phillips head stainless lag screws, it helps reduce corrosion. And they still just "screw in".
(No Longer at Inland RV)
Old 10-17-2009, 09:08 AM   #4
Profile:  1976 25' Caravanner
Campton , New Hampshire
I replaced all the lag bolts with SS . When the awning is up there should be no forces on the arm except the weight of the arm . The awning spring is holding the awning in the roll up position . When the awning is down the arm is pushing against the trailer so there is not much force there either , and the fitting is sort of locked onto the rub rail . Not sure why you would shear a bolt head with the exception of a strong wind with the awning down. Might want to check if something is bent or out of alignment.
ticki2 is offline   Reply With Quote
Old 10-17-2009, 11:31 AM   #5
Safari64's Avatar
Thanks for the help. The awning was up, secured, on the road. Now I know how to replace jalousie panes too (easy).
Safari64
How to fix attachment slimitch Awnings 2 01-28-2009 05:30 AM
Photo attachment woodedareas Forum How-To's & Support 6 03-01-2007 02:05 PM
Acrylite (Smoked, Curved & Installation) Cat Windows & Screens 4 05-23-2005 02:04 AM
Tent attachment for AS Zmod Our Community 2 02-20-2005 02:02 PM
Curved WindowCurtain Railing Attachment winner Upholstery, Blinds, Walls & Interior Finishes 4 11-01-2002 08:14 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
