Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 09-11-2002, 10:58 AM   #1
Joan D'Andrea's Avatar
Profile:
Send a message via Yahoo to Joan D'Andrea
'78 Sovereign Awning
Good Morning.
ALMOST a new owner here. Thanks for all your suggestions so far. NEW PROBLEM According to the past owner, the Sovereign I will be getting has troubles with its awning. The owner says the advertisements for the original awning stated it could be easily lowered and put back by a woman, but that has not been his experience. He says it jams and wants to bend. He thinks the arms of the awning are too light for the weight of the awning plus its roller and suggested I look around for some aftermarket arms that will work with the original awning. I haven't tried lowering it yet, but will as soon as we take delivery. Does anyone have any suggestions. This is the original awning supplied with the '78 Sovereign. I have seen a few pictures on the web with this awning extended. I e-mailed a salvage supplier and he said that arms on awnings are not interchangable so if this one is trashed I will have to get a brand new, errrr used, awning. That would be a big expense and is not an option right now as the $$$ I put out for the AS itself are every cent I have. Any owner with experience with the awning provided with the Sovereign: PLEASE WRITE ME. Thanks
Kalakkala II
Joan D'Andrea is offline   Reply With Quote
Old 09-11-2002, 10:33 PM   #2
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
Awning
J,
Is it a Zip Dee?
If so does it have a bow in the roller that the fabric is rolled on to?
If so there is a way to bend it. It requires 3 people. The proceedure is outlined in the owners manual from Zip Dee. Zip Dee has a web site and the manual is available from them. Godd to have it for other reasons too. BTW the best part, the fix is free. And I got my manual free too when I ordered a part that I needed.
>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.8L, E4OD, 3.55 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 09-12-2002, 09:12 AM   #3
Profile:
Thanks for the reply. I will check out the name Zip Dee. So far I haven't seen it posted on the awning, but apparently there is a drawer full of manuals for the rig. I take delivery next week. I'll get back to you if I don't understand the process. Thanks again.
Kalakkala II
Old 06-08-2004, 01:49 AM   #4
Profile:
Awning on 78 Airstream
Look on the awning arms. CareFree has their name on a sticker that you can see in the rolled up position. I don't know about the others.
As for my search, my time is up, I'm just going to have to purchase a whole new set-up, because I have to move due to a DOT road project.
Looks like I'll be purchasing a ZIpDee, just because of the other posts here, and still being able to get parts, if needed.
CareFree changed their design, which made all CareFree curved arms from 1969 to 2000 for Airstream obsolete. If it's damaged, they have no replacements.
It's really crazy to have to spend $1000.00 or so to buy a new awning, just because a $150.00 part is damaged.
So from here on out ZipDee has my business.
Ineedparts is offline   Reply With Quote
Old 01-04-2005, 11:18 PM   #5
APB
APB's Avatar
Profile:  Escondido , California
On my '78 Soveregin International the awning is ZipDee and the name is cast into the ends of the support arms ( the arms are made of an extrusion with castings bolted to the end.
If the awning tube is not bent and it doesn't want to roll up (mine takes a push to get it started) the tension on the spring in the tube may not be strong enough.
Go to the ZipDee web site and find the instruction on how to remove the Awning. This will tell you how to relieve and replace the tension on the roller.
Hope this helps...
APB
Bluegrass is flat picking good!
APB is offline   Reply With Quote
Old 01-05-2005, 07:12 AM   #6
Still Working
smily's Avatar
Profile:  North Charleston , South Carolina
Z lock
Zip Dee awnings sometimes have a lock feature called a Z- lock.
This is fitted into the forward end of the awning tube.
These devices get water into them over the years and tend to seize. This will cause the awning to act as though the spring is shot or seized.
Zip Dee service will tell you, that if the awning will roll on its own to any degree, the spring is not the problem.
I had the same problem and assumed the spring was alomost shot. I called Zip Dee and talked to them. They sent me a 98 dollar Z-Lock. When I replaced the Z-lock, the awning rolled so easily, it almost snatched me off of the ground.
Replacement is simple and the new one comes with all parts and directions.
go here for directions www.zipdeeinc.com
smily
Ken Smillie
My 1994 36' Classic MH is for sale
See it in the classifieds
smily is offline   Reply With Quote
Old 01-03-2006, 08:34 AM   #7
Profile:
Zip Dee
If the awning is original it should be a ZIP DEE, just as the others stated, they carry a full line of replacement parts for the awning, and they are pretty helpful over the phone too.
I have an older awning that the retention pins wore out on, on the extention bars...I replaced those and it works wonderfully, I also cleaned them up and lubricated the joints.
ZIP DEE is an awesome product and is designed to be easy to use...if that is not the case it is just in need of some maintenence, good luck
they are easy to find on the web too
hhessig is offline   Reply With Quote
Replacing Awning Arms beachmpk Awnings 7 10-05-2004 02:28 PM
Lug Bolt Size for '78 Sovereign dinoburb Wheels 2 03-20-2004 04:34 PM
Is the roadside awning option for a 28' Classic really just a single 19' awning? Dave Jenkins Our Community 1 08-17-2003 04:07 PM
Awning Repair cesurman Awnings 0 08-16-2002 12:57 PM
