Old 10-24-2010, 08:28 AM   #1
1970 21' Globetrotter
new orleans , Louisiana
65 globetrotter
can you add an awning to a 65 globetrotter? I am thinking of purchasing one but really would like an awning. I know some purists will cringe but thats not me.
jhirstius is offline   Reply With Quote
Old 10-24-2010, 08:47 AM   #2
Yes, you can add an awning to your 65.
BUT, be extremely careful what brand you pick.
The arms must be shaped to the contour of the trailer.
The only company that still has the correct shaped arms for a 65, is Zip Dee.
Typically, if you buy another brand, and install it, and then you learn of the improper fit, they will not take it back.
Old 10-24-2010, 09:11 AM   #3
RGates
Randy Gates's Avatar
1968 20' Globetrotter
Thousand Oaks , California
You have options
Instead of going through the expense of a roll up awning, have you looked into a rope and pole awning? Check out a website "Marty's Vintage Trailer Awnings" (www.trailerawning.blogspot.com). She makes awnings custom for trailers. Also, has the sunbrella material with the stripes running in the correct direction. Todays material runs in the opposite direction. I replaced the material in my roll up Zip Dee and rebuilt the frame assembly.
Hope that helps.
Randy Gates
Randy Gates is offline   Reply With Quote
Old 10-24-2010, 09:37 AM   #4
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I don't think we have many purists on this board to bother you!
I've seen vintage with awnings, and ones with pole awnings, and I have to say I like the vintage pole awning look better. There's nothing wrong with either one, so just pick what suits you. So if you question is 'after I buy it can I add one?', the answer is yes, no problem at all.
Stephanie
Old 10-24-2010, 10:29 AM   #5
1962 16' Bambi
2001 31' Limited
1985 29' Sovereign
Jenison , Michigan
Images: 8
We went vintage awning on our 62 and are very happy.
62bam is offline   Reply With Quote
Old 10-24-2010, 11:07 AM   #6
1965 20' Globetrotter
Bromsgrove , Worcestershire
This is my '65 GT fitted with a pull out awning.
I've not had the courage to open yet and it will definitely need new fabric, but at least you can get the idea of what it'll look like folded up.
As for the purist aspect, go with what suits you, enjoy it and let the purists spend thier cash and enjoy what they want.
Chiefy is offline   Reply With Quote
help with 63 globetrotter Wild Horse Member Introductions 4 02-03-2008 06:02 AM
'62 globetrotter wunderful62 1962 Safari 1 10-23-2006 07:29 PM
62 Globetrotter Maya Furnaces, Heaters, Fireplaces & Air Conditioning 3 11-04-2005 06:41 PM
62 Globetrotter Maya Water Heaters, Filters & Pumps 4 10-31-2005 01:22 PM
'63 Globetrotter Mark Wiltrakis 1960 - 1964 Globetrotter 1 07-11-2005 12:22 AM
