Old 04-15-2015, 09:39 AM   #1
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
18' Traveler Awning
I could use a little advice.
The Rail is 8' so I was thinking about 7'9" Wide for that Rail. Curious about the Length 8' or 9' or?
I am also considering Window Awnings but would appreciate any advice.
thanks in advance!
ID:	236349   Click image for larger version
Steve
1958 California Built 18' #18-4092
http://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 04-15-2015, 09:54 AM   #2
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
I prefer 9 ft. Assume you mean a pole awning? No experience with AS window awnings but seems like a great idea.
BambiTex is offline   Reply With Quote
Old 04-15-2015, 10:29 AM   #3
1976 31' Sovereign
Oswego , Illinois
Zip-Dee makes awnings of any size for AS & other brands, I don't no how long they will make for door side. Measure from where wrap around front & back meets side panels will giv what size needed as arms secure into sides at these points, they also make window awnings any size but will need awning rail for them. Phone Zip-Dee they will answer your questions. Measurements are critical as they make them to those specs.,if you don't want to install yourself they have qualified dealers. Any of awning manuf. will make window awnings but only Zip-Dee makes curved arms for sides of trailer that I no of.
Curved arms not needed for windows. Zip-Dee is best awning manufact. plus if doing sides & window fab. will match colors chosen. They only use sunbrella fabs. not laminated as others use. You can also make slip on covers for windows, if you pm me I can explain how as several ways to make. I made some for 66 & 67 windows, pur sunbrella fab. matching full awning.
Old 04-15-2015, 10:42 AM   #4
1958 18' "Footer"
Thanks BambiTex, I thought that 9' would be a better fit.
Sorry featherbedder, I should have been more specific. It will be a Rope & Pole Awning to fit my existing rail. I agree that Zip Dee makes great awnings, I have them on my '82 Newell.
The 18' Traveler will be as close to original as possible today. The link to my restoration is in my signature.
Also found this thread about Awnings and Window Awnings;
http://www.airforums.com/forums/f442...ngs-72400.html
Steve
Old 04-15-2015, 11:01 AM   #5
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Pole Awning
Had this one made for the Bambi II.
Had a similar one made for the FC - plan to try it out this weekend.
traveler :: 1960 Airstream traveler mvperini Airstream Registry Discussions 0 01-26-2013 01:23 PM
30 amp or 15 amp / 59 Traveler bkpine Electrical - Systems, Generators, Batteries & Solar 14 09-14-2006 07:10 PM
closet latches 59 Traveler cindy Cabinets, Counter Tops & Furnishings 2 03-22-2003 01:22 PM
59 Traveler bkpine 1959 Traveler 8 11-11-2002 10:31 PM
35 new pictures posted of 58 Traveler restoration williamhenshall 1958 Traveler 12 09-03-2002 10:08 PM
