Old 06-04-2013, 09:52 AM   #1
sunny 75
sunny75's Avatar
1975 27' Overlander
selah , Washington
Winter was hard on 1st year's shine
After a winter of skiing/camping, the 200 hours of polishing last summer needs a touch up. The salt from the winter roads has made a mess of the lower half of the trailer. Any suggestions about which grit I will need to start with? I'm hoping to not have to go back to grey bar.
sunny75 is offline   Reply With Quote
Old 06-05-2013, 08:32 PM   #2
reinergirl's Avatar
Hollis , New Hampshire
I would start with the least aggressive bar....say red or pink , or even white . If it doesn't work you can always go more aggressive. If its not bad perhaps you can just cyclo with s?
reinergirl is offline   Reply With Quote
Old 06-06-2013, 08:35 AM   #3
sunny 75
sunny75's Avatar
1975 27' Overlander
selah , Washington
winter damage
Thanks for your quick reply. That's kinda what I was thinking. Would you remove the trim like we did last year before polishing?
Old 06-19-2013, 07:11 PM   #4
reinergirl's Avatar
Just FYI, I was working on a new panel today and just the cyclo with nuvite c or s didn't do it. I compounded with the white rouge, then used the cyclo with s and it's very close to the mirror finish I'm getting on the older panels.
If it's easy to remove the trim, I would. My insides still out so I'm removing almost everything and will buck them back on when I finish. If removing your trim means replacing buck rivets with olympics then I would work around it.
