Old 08-08-2010, 01:05 PM   #1
1978 28' Ambassador
Savannah , Georgia
Window trim salt corrosion
AS sat by the marsh for 8 years. I have this white film on all window frames and door frames. Have tried different compunds, polishes, buffers and other things to remove the white residue. The only thing that I have found that works is fine bronze wool I bought from a marine store. It is very labor intensive. I have to polish each square inch. 1st picture is the before and 2nd picture is where I partially removed the residue with the bronze wool. Any help or suggestions appreciated. The areas around the rivets are the hardest parts. Thanks. Jack
Name:	Airstream front clearcoat 001.jpg
ID:	108339   Click image for larger version
Name:	Airstream front clearcoat 006.jpg
Skamper1 is offline   Reply With Quote
Old 08-08-2010, 02:08 PM   #2
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Jack,
As you are finding out aluminum and salt air don't mix. Have you tried a green Scotch Brite pad? No matter what you do, It is going to take a lot of elbow grease and time to clean your window frames. After you get them cleaned and polished I would suggest taping them off and spraying them with a clearcoat of Krylon Crystal in a rattle can. That should preserve your work for a while.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 08-08-2010, 02:11 PM   #3
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Had some of the same on my belt and trim lines I used 400 grit sanding sponge wet to get most then went a finer grade and compound to get out the scratches made by the 400.
bwaysteve is offline   Reply With Quote
Old 08-08-2010, 04:23 PM   #4
1978 28' Ambassador
Savannah , Georgia
I used the 220, 320, 400, 600 wet sanding on the propane tanks. Then coarse and fine rubbing compound. Finished with Mother's. Really liked the results, but was hesitant to use wet sanding on the window trim. Will give it a try tomorrow. Thanks. Jack
28' Excella window trim Dean Rawson Classic Motorhomes 2 07-07-2010 07:49 AM
need new inside window trim T&Cairstream Windows & Screens 4 02-19-2008 05:26 PM
Need argosy window U trim nodpete General Interior Topics 3 07-03-2007 04:11 PM
Safari Window Trim Devoman Windows & Screens 0 02-21-2007 03:58 PM
Outside window trim Lido&Linda General Motorhome Topics 9 12-06-2003 04:30 PM
