Old 05-03-2007, 07:21 PM   #1
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Window frame clean-up
Who among you Airstream owners has a tried and true method to clean up mildly corroded window sill and window hardware. I was thinking to remove and soak the the Corning glass latches in parts cleaner but I suspect that would be too harsh on aluminum. Clean the frame sill with ????? 000 steel wool and mineral spirits? Thank you for your help.
Neil and Lynn.
Name:	AS window sill.jpg
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 05-03-2007, 08:28 PM   #2
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
In the past I have removed the latches for the lower part of the window and cleaned up the frames with Simple Green or citrus cleaner, synthetic steel wool and plastic or brass "tooth" brushes for the corners.
Don't use real steel wool. The steel fibers will imbed in the softer aluminum and rust in a short period of time.
I used to be able to easily find synthetic steel wool from 3M but can't seem to find the finer grades now. Get the finest you can find and go easy with the elbow grease.
The latches are really simple and get just get a dab of grease when put back on.
Good Luck, Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 05-04-2007, 07:18 PM   #3
FreshAir's Avatar
1966 24' Tradewind
Good Luck, Tom.
Thank you Tom. I would have used steel wool as an obvious method. Simple Green I got. It works on just about anything.
Neil
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Fuzzy Window Seals Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 34 07-21-2010 02:53 PM
Curved side window replacement michel88 Windows & Screens 7 09-29-2006 09:20 AM
leaking around front window of 1969 Caravel David Henderson Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-27-2002 11:01 AM
side front window for '74 Argosy dootsie Windows & Screens 2 10-23-2002 08:28 AM
Acrylite Window Replacement Gordon Watt Windows & Screens 12 08-12-2002 08:46 AM
