Closed Thread
Old 04-28-2005, 08:49 AM   #1
Elgin , Texas
Images: 164
Who's peddling SS these days?
Ready to give Southern Shine a test whirl, and wondering who is selling it these days. Anyone know?
bake315 is offline
Old 04-28-2005, 09:06 AM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Try http://www.southernshine.net/
Let us know what ya think of the results, never heard of it before...
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline
Old 04-28-2005, 09:16 AM   #3
Elgin , Texas
Images: 164
Thanks for this - I tried Gord's and liked it well enough to consider it again in the future, but this time I wanted to try something with a bit more body to it.
bake315 is offline
Old 04-28-2005, 12:32 PM   #4
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I have used SS and found it to work in some of the areas that Nuvite didn't work as well. Its not the end all of polishing but works quite well with compounding. It is really messy. That is an understatement.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is online now
Old 04-28-2005, 06:19 PM   #5
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
Also try: http://www.steeda.com/store/-catalog/polish.htm
So Long!
Bob Thompson is offline
Old 04-29-2005, 06:54 AM   #6
What is this stuff?
Another high priced polish? What color? Maybe if it works as well as flyfisher says then it also can be duplicated from rouge- white? green? red?...
I saw some stuff called White Diamond polish- not anywhere near as expensive, and the guy using it was getting great results on a tank truck where my mechanic works on mine. Buffed out nicely but definitely made from white rouge, and he could have saved himself a lot by making it in a blender. I showed him the recipe and some pix and he was saying he was happy with this stuff, but at $10 a bottle and he was using 5- 12 ounce bottles, he'd have more with a stick of rouge and a gallon of mineral spirits.
Rouge- less than $10
Mineral spirits- $10
Old plastic bottles- $0
Beating the stranglehold of marketed products controlling minds of unsuspecting Airstream owners and freeing their time for more camping...
PRICELESS!!!
No joke- see if you can't make the same stuff yourself- check this SS color and compare it to a rouge bar and try it!
TravelCloud is offline
Old 04-29-2005, 07:22 AM   #7
Images: 59
Here's another aluminum polish. There is an '81 Excella at the bottom of the page. Gord is (or was) a forum member.
http://gordsaluminumpolish.com/index.html
http://www.airforums.com/forum...ad.php?t=11776
According to Gord, it does a good job of removing alclad. ????
markdoane is online now
Old 04-29-2005, 08:36 AM   #8
Images: 67
Unhappy
TraveCloud, at first I thought you were bashing SS which is a product I use and really like, but then I realized where you were heading! You're absolutely right! I like the way you think! Just a question..... where do you buy a rouge bar?
So Long!
Old 04-29-2005, 08:56 AM   #9
Images: 67
I found an answer in just a few minutes with Google: http://www.americanjewelrysupply.com.../compound.html
So Long!
Old 04-29-2005, 09:28 AM   #10
Images: 59
Bob,
Those are a little pricy. Try this:http://www.tarheelparts.com/cgi-bin/...d=7032127.8104
Old 04-29-2005, 11:51 AM   #11
Found this with the airport guys-
www.sattexcorp.com and had to dig through their dumpster to find it...
I'm not bashing anything, I don't see paying all that money for what can be made for 20-30 bucks. Thats what you need to make a gallon. If you like a particular polish and only need a bottle here or there- go ahead. If you need some to polish a Harley- go ahead. When we need a LOT to do a 20'+ trailer and someone sells me something that they want $50 for a tiny little tub and says I have to spend more time using it- sorry. Especially when it takes 8 tubs of it to do the same job. You're talking $400 in just polish alone, and all made from the same bars of rouge that Sattex and tarheelparts.com sell for less than $10? Come on, guys! This is not what I call acceptable- you do it if you want, but WHEN I start, it won't be that way. And stop trying to convince people that there is only one way- its not true at all- I'm simply suggesting that there are MANY ways- of which rouge and a drum polisher would yield the best result and in the least amount of time.
Disclaimer- I HAVE NOT DONE THIS MYSELF, HAVE ONLY SEEN IT DONE THIS WAY ON 2 DIFFERENT TRAILERS AND 3 AIRCRAFT. I HAVE ALSO RECEIVED PM'S THAT SAY OTHERS HAVE DONE THE SAME BUT ARE AFRAID TO MENTION IT HERE.
Its almost like there is a consortium of people who own stock in these cottage companies and are protecting their investment. Shouldn't most people WANT to explore a faster and less expensive alternative- I certainly do!
I hope someone else has the opportunity to check out these options on their own trailer, as I'm still a ways from being able to start. The wet sand/green rouge/white rouge program seemed to be incredibly effective on a very dull trailer- when combined with proper pads on a high speed buffer.
Old 04-29-2005, 02:37 PM   #12
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
There are a lot of truckers who use the mineral spirits/roiuge method. I tried it on a bumper on my AS it worked ok, but not as good as the Blue Magic and Mothers aluminum polish I used. I also use the Liqiod Glass polymer sealant on my plasticoated areas, which polishes only mildly, but then it seals the area so that further polishing is not needed for a long time. On unsealed panels it has held up over a year after i stripped them and polished, although not to a mirror finish.
The chemical companies researching polish and wax and stake their future sales on the fact that you will buy them more than once, which means they have to work.
Which one you prefer is up to you. How much you want to spend is also up to you.
As for me I enjoy trying new products and I am happy to report my results.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
ALANSD is offline
Old 04-29-2005, 04:05 PM   #13
Wink
Amen brother!
Isn't it a shame that any members here would fear the free exchange of knowledge. But I know it is a fact that some do. IMHO it all is based in the past attacks on posters regarding the polish questions and the scoldings and censorings that have too often taken place in threads regarding various subjects.
However I have never read or even imagined that any of the forum "Bosses" were in the polish business. If they are it would be enlightening, are you aware that any of them are?
Assuming that they are not, it is mind boggling to me why trailer polishing is at all a contencious subject. It's certainly a mystery to me.
I thank you for your revelation and recipe. I for one am in full agreement that a dollar saved is a pleasure earned.
I will burn a copy of your posts in case this thread is removed.
I had never heard of this "rouge" before.
Where can I learn more about the different "colors" of rouge? Does the color simply indicate the grit?
Thanks much
Flicka
Hit'nMiss is offline
Old 04-29-2005, 04:12 PM   #14
Elgin , Texas
Images: 164
...and had to dig through their dumpster to find it...
You are a man o' passion aren't ya? Now come on down outta that tree!
Seriously though, in the end we're all going to do what works best for us, either in terms of labor or dollars. I really appreciate all of your digging and research - they can only be of benefit here. I'm interested in trying new products whenever I happen upon them, too. Just yesterday evening I found a product at the HEB (for those folks outside of TX that's a grocery store) called Mr. Metal. I figured for $2.50, what the hey? Anyway, it did OK, I guess. Pretty easy to work with, by hand, non abrasive. Easy to remove, doesn't get all over you. Though I didn't try it, probably not good with a buffer because it dries very quickly. Creamy, strong ammonia smell. Seems like it would be good for use in a spot, touch-up situation on already polished aluminum.
bake315 is offline
Closed Thread
Question about my 2000 Dodge Dakota kentlundy Tow Vehicles 16 09-02-2008 09:12 PM
A cat diary of a few days FrankR The Pet Forum 4 09-22-2005 10:23 AM
11 days in a Caravel! Stefrobrts On The Road... 14 09-17-2004 07:14 AM
