Old 03-03-2010, 08:21 PM   #1
Titusville , Florida
Which Stripper (Clear Coat)
I bought a can of Aircraft "suppose to be good stuff", work in 10min paint remover from Wally World (Mal-Mart) the other day to start stripping my 93 Excella upper nose area, waited 10-15mins like the can said, tried scraping it off; Nothing, tried again, waited longer, nothing.
What do they use for clear coats on these things, it's awfully hard. What stripper works best.
Caltech is offline   Reply With Quote
Old 03-03-2010, 08:58 PM   #2
tcrum's Avatar
1978 31' Sovereign
Cookeville , Tennessee
i've heard the Removall 220 is good, however, stuff is now produced in South Africa, just becoming available again in the US. Vintage trailer supply is expected to have some next week. Since it wasn't available I bought some DoradoStrip 3010. It is supposed to be very similar. DoradoStrip 3031 Architectural Paint Remover gal spray or brush
I am going to give it a try this weekend. We will see what happens.
tcrum is offline   Reply With Quote
Old 03-03-2010, 09:04 PM   #3
Let me know how it does. I am not going to start on mine again until the end of next week. I hope
Old 03-03-2010, 09:25 PM   #4
Aircraft stripper, is one of the top quality strippers. We have used it for many years.
Normally, you hose it off. Scraping it off will damage the metal appearance.
Did you put a thick coat of stripper on the clear coat?
Old 03-03-2010, 09:48 PM   #5
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Caltech,
I tried Citristrip on a portion of myAS It worked,but only 60 out and it dried quickly.
It did work but took 2 coats.
I have been waiting for Removall since last month so I tried this.
I bought some Aircraft Stripper by Kleen Strip to try tomorrow.This seems to work well from all the threads I have read.I tried to find Hydro Strip 502(the same formula as RemoveAll but no luck.
I will report after tomorrow.
bwaysteve is offline   Reply With Quote
Old 03-04-2010, 01:04 PM   #6
Hey Andy, It was in a spray can, and yes I put it on pretty thick. It took the glue off of the back of the old Wally numbers, but did not seem to touch the Clear Coat.
Ron
Old 03-04-2010, 01:13 PM   #7
Ron
I don't like the spray can stuff very much. I don't think it gets thick enough. Try some that comes in the big square can, pour it out over the surface and brush it on really thick with a brush that you don't mind sacrificing to the cause. Wear heavy chemical gloves, and face protection.
Old 03-04-2010, 02:32 PM   #8
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
1956 22' Flying Cloud
Rutherford Co. , North Carolina
for the interior zolatone we used Klean Strip in a metal can, it came with a refillable spray bottle from home depot. we initially went with the milder 'citri strip' but it just was a gooey mess, and only really took off a 'tint' of the color. the Klean Strip , when sprayed on heavily, got under the paint, make it look crackled, and with a PLASTIC scraper it took no effort for it to just fall off the wall.
this is what ill use on the outside too, when its warm enough here in NJ / philly area.
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
Old 03-04-2010, 02:53 PM   #9
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
I also used the before mentioned stripper. Worked really great, you just have to have patience. If you put it on as directed in one direction thickly with a brush, wait then carefully with a plastic scraper remove the lifted clearcoat. While the surface is still damp use mineral spirits or paint thinner on a cloth or paper towel to remove the remainder of the clearcoat. You may have to apply more stripper on the stubborn spots and repeat the procedure mention before. Be sure to have a smooth edge on the scraper to prevent scratching the surface, this could be accomplished by using a very fine sandpaper to clean and smooth the edge of the scraper.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 03-04-2010, 03:49 PM   #10
2001 30' Classic S/O
2001 36' Land Yacht XC Diesel 300 hp w/slide
Helotes , Texas
I used Removall 220 last summer. Did the upper half of a 28' in one Saturday. Brushed it on 2 sections at a time, waited 1.5 hours used a pressure washer and done. I used less than 1 gallon
lsmith is offline   Reply With Quote
Old 03-04-2010, 06:00 PM   #11
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
I used the Aircraft stripper and it worked great and not that hard to use.
You paint it on and hose it off, skin has to be cool and works best when not in direct sunlight.
Garry
Old 03-04-2010, 08:39 PM   #12
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
I used Kleen Strip Aircraft Stripper(the blue can w/ the airplane on front) It was so much better than the Citristrip I tried earlier.I guess I could have left it on longer than 10 mins. but it did a great job with just a few small spots I redid.Just hosed off(no scraping)Tomorrow I will leave it on 20 min.
I am using gloves and a 2 stage face mask w/ safety glasses.long sleeve shirt.
Old 03-05-2010, 08:11 AM   #13
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
oh yea, i got one of those disposable jumpsuits @ HD. that stuff burns like a.......
anyway, don't get it on your skin.
Old 03-05-2010, 08:30 AM   #14
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Bix
BIX, works. Available at Home Depot
Don
adonh is offline   Reply With Quote
clear coat in patches safari 28 Ribs, Skins & Rivets 4 05-15-2008 09:29 PM
Has Any One use microbille on clear coat? Perry Cleaning, Stripping & Polishing 6 12-10-2007 03:42 PM
Clear Coat on Everything! Sherry S Upholstery, Blinds, Walls & Interior Finishes 2 08-07-2007 08:13 PM
touch up clear coat... safari05-25 Clearcoat, Exterior Paint & Trim 2 10-22-2006 09:14 AM
Condition of Clear coat James Schmidt 1993 Excella 1000 2 05-15-2002 08:23 AM
