Old 04-05-2011, 08:43 PM   #1
NicheVintage's Avatar
1965 26' Overlander
The Gorgeous Pac Northwest , Washington
Images: 34
Which should we do first?
Our ol' girl is finally polished. We now need to cyclo her and re touch the seams, etc. Which step should we do first? Also what is the best way to re seal the seams?
Thanks for the help.
WBCCI# 2578
Four Corners Unit
Our travel and resto blog:
http://web.me.com/tiffanydanley
NicheVintage is offline   Reply With Quote
Old 04-06-2011, 11:01 AM   #2
1969 27' Overlander
pharr , Texas
did you have any photos a inside restoration before and after.
BDD2939 is offline   Reply With Quote
Old 04-06-2011, 12:35 PM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We actually sealed our seams before even compounding.
Here's our "seams first" reasoning - just our logic, not everybody may agree. We scraped out all the old, cruddy sealer with popsicle sticks & mineral spirits, then compounded just the seams, cleaned them really well - again with popsicle sticks & mineral spirits, then resealed them with fresh vulkem/parabond. For awhile, our trailers have had just the seams polished - which looks kinda goofy, but cool at the same time. Then we went back and compounded (and eventually Cyclo-Polished) the rest of the trailer in the end.
We've done this on both trailers and feel that it makes sense for a couple of reasons. If you leave the old sealer in place while polishing then reseal afterwards, the old sealer can chunk out and get imbedded in the buffs which causes undue scratching. By doing it this way, you can get the seams buffed up really well, then sealed which leaves the sealer cleaner in the end. If you seal first w/o polishing the seams - the polishing compound gets gooped up on the new sealer because we are trying to get the 55 years of oxidation off and working the area harder.
As we've worked on the trailer, we would take things off, then polish around the area before putting parts back on. This way, the hard work is done around all the details, seams, joints, drip caps, etc. and just the flat parts are left. Yes, we still will go over those areas again, but it'll be a touch-up, not the original cut, so the compound isn't as big of a deal.
Since you have already compounded, I would do the seams now. That way you can go back and touch up any areas that might get scratched while sealing before you Cyclo-Polish. Then Cyclo the whole trailer...
Just my 2-cents...
Shari
Old 04-06-2011, 02:11 PM   #4
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Hi Shawn,
I would seal your seams now. You can use either Parbond, Acryl, or Alcoa gutterseal. I prefer Parbond but they all work great.
If getting your seams dirty is a concern when you cyclo, then just tape over the seams. That's what I plan on doing.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 04-08-2011, 12:39 AM   #5
1965 26' Overlander
Images: 34
Since it's been a while, here are some recent pics. Got the paarbond in from inland so after rally this weekend, its back to work. Seems like it never ends...
ID:	126398   Click image for larger version
WBCCI# 2578
Four Corners Unit
Old 04-08-2011, 12:42 AM   #6
1965 26' Overlander
Images: 34
Oh, and BDD2939 you can see interior pics on my travel blog link in my signature
WBCCI# 2578
Four Corners Unit
Old 04-08-2011, 07:24 AM   #7
InsideOut's Avatar
1956 22' Safari
Images: 108
Looks GREAT!!!! Someone has been busy....job well done!
Shari
Old 04-08-2011, 07:41 AM   #8
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
She looks fantastic!!!
1958 Overlander
4CU 1st VP
