Old 08-19-2013, 09:02 AM   #1
parrotheadrv's Avatar
1973 29' Ambassador
troup , Texas
Where to start??
Looking to start on the outside skin...Think the po started stripping it but not sure.....here's the photos....thoughts on what to do first....
ID:	193593   Click image for larger version
ID:	193595   Click image for larger version
parrotheadrv is offline   Reply With Quote
Old 08-19-2013, 09:04 AM   #2
1973 29' Ambassador
troup , Texas
Is the Eldorado PR-5044 the stuff to use for stripping ??
Old 08-19-2013, 02:36 PM   #3
outofcontrol's Avatar
1996 28' Excella
Portland , Oregon
That looks like blue tarp damage to me. The black lines could be where the tarp rubbed on the clear coat. I only guess that because of where they are, and it would be a strange method of polishing if that's the way they attempted to start.
I'm just buying paint stripper from Home Depot. Only because it's 1 mile from my house.
Just use blue tape to cover anything you don't want to damage.
-Kevin
1996 Airstream Excella 28'
2007 GMC Duramax 4x4 CCSB
outofcontrol is offline   Reply With Quote
Old 08-24-2013, 10:16 PM   #4
1973 29' Ambassador
troup , Texas
So is this clearcoat that I see peeling and should step one be strip the whole trailer? Other than tape off the windows and light covers is there anything else to worry about? Not worried about pin-stripe in grooves as it is almost all peeled already and will have to be replaced. Thanks for any help
Old 09-15-2013, 06:48 PM   #5
1984 31' International
1969 23' Safari
Flint , Michigan
Yes...to answer your question, the first step is to strip your AS. I used Citristrip from Home Depot. All you have to do is brush it on and the easiest way to get it off for me was to power wash it off.
Good luck with it and fun....it will be well worth the time spent
Dan
lundrunner is offline   Reply With Quote
Old 09-22-2013, 11:48 PM   #6
1973 29' Ambassador
troup , Texas
What kind of tape did you use to tape off windows and such?? Did you remove all your light covers or tape them off also??
