Old 04-28-2007, 10:11 PM   #15
r&kweber's Avatar
1959 22' Flying Cloud
Seattle , Washington
I noticed that when I used the F7, for the heavy oxidation removal, I had to change the pad four times. The pasty heavy accumulation of oxidation slowed the polishing process. The dirtier the pad was, more compound was left on the trailer. For me, the cleaner the pad the better for me. Dave got really different results than I did, so you may get a completely different result too
I think you will always get black residue. I doubt you will get every bit of corrosion off, and that is what the black stuff is. The residue left on the trailer will come completely off with naptha, I think I will wash the trailer clean with that stuff between grits next year when I do it again. Looking at pictures of people working with the Cyclo, presumably with S grade, their white towels are turning mostly black.
IMO, the lowest setting is too slow. To get the whole area warm, I needed more RPM. Then again, it was a cold Seattle weekend in the shade when I did the polishing. If it's warmer where you are, you may not need as much speed.
I hope this helps. After all the threads and websites I read before polishing
I still felt like I was making it up as I went.
Ryan.
r&kweber is offline   Reply With Quote
Old 04-29-2007, 03:15 PM   #16
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
I'm getting a lot of accumulation also, the 'scruffing' helps some but I have found its just as well to wash the bonnet about once an hour.
Ryan.
I dont understand something here, why do you want the area to be warm? Isnt this an abrasive process? I thought the idea was to keep the metal from getting to hot. Can someone explain?
On another note, I have decided the best reply to the question about how long it takes to do this: "if you are worried about the time, you dont want to do it". At this point, I suppose I am about 1/3 of the way around with the F7 and C. I have learned to not be reluctant about going for the heavy grit.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 04-29-2007, 05:09 PM   #17
Streamin 65's Avatar
Columbus , Ohio
Images: 14
Shine on!
Hey Gen,
The metal is just going to get warm as you polish. It's the nature of the beast. The goal is not to let it get hot enough to leave burn marks because they take a bunch more time to polish out. I spent many, many hours polishing and learning what works the best (at least for our coach) last spring. 40 years of oxidation does not remove easily and it took quite a few passes just to get the major stuff off. Last year I did the whole thing with f7 and c and it still didn't look great. There was still some swirl marks,cloudiness, etc that I just let go. I grew tired of doing it and wanted to spend some time enjoying the thing! (And did!)
Today I picked up the polisher and the F7 again. Did almost a whole side in 4 hours- it's clean, bright, and very close to perfect. Swirl marks are there, but I will work those out with the C and S. Anyway, to make a long story short, if your coach is pretty bad, just get done what you can this year. Unless you have plenty of free time and a ton of dedication it may not be possible to get it all polished this year (depending on the condition of your trailer of course) Plus, you'll be doing it again next year anyway, it'll just take less time. What works for my coach may not work the same on yours, but I'll share my "secrets". First, there is some varied opinions on how much polish to use. The answer, of course, is "just enough". I've found that I use a little more F7 when doing the heavy compounding. A wet fingerprint seems to be enough when using S, but I use a little more with the F7 and C. You don't want so much that there is a lot of black residue that takes a few passes to remove, but I've found that if there is a some black residue left after the first pass that cleans off with the second pass I'm using the right amount. I like to keep the speed of my buffer around the number 2 setting and take slower passes. This has produced the best results for me. When the pads get that shiny look, I'd suggest getting a buffing wheel spur to clean them. They are about $5 and work so much better than a screwdriver. Finally, when it seems the pad is getting shiny frequently, it's getting loaded up with compound and due for a cleaning. Get yourself a few pads if you can, having spares will keep you up and running. Finally, Good luck man! It's a labor of love, but the results are worth the work. Post some pics of that shiny rig! And here's one of ours from last year to help keep you inspired--dave
Name:	65 Airstream polished.jpg
Streamin 65 is offline   Reply With Quote
Old 05-27-2007, 07:14 AM   #18
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
Originally Posted by Gen Disarray
Also, I recall reading 400 rpm is the idea speed for the grinder, does anyone know which setting that is on the harbor freight grinder? Thanks
For the first cut on our Bambi II, we use a Milwaukee 1/2" variable speed drill and "feathered" the speed, as needed. We also use the spur tool for periodically cleaning. We keep a few extra pads around to keep moving on the polishing without having to stop to clean all the time.
I have a question about overnight or long term cleaning of the pads. What works to thoroughly clean the pads? We have tried to clean them but they never seem to get clean (i.e., there is always a slimy sludge left behind).
Streamin 65: nice job on the polishing! I am inspired! Where are my sunglasses?!
The "polisher" is taking a break in the picture below!
Name:	Brian taking a break.jpg
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 05-27-2007, 07:39 AM   #19
Columbus , Ohio
Images: 14
Buffing pads
I was once able to put them in the washing machine, but the wife bought a new set and will no longer allow me to put anything I don't wear on my body in it. So what seems to work best now is to spur the wheel and clean off what I can before removing it. I then soak them in a bucket of water for a little while. Finally, I take them into the backyard and hose them off real well. Once thwe wheel dries, spur it again and the black slime will have become a fine dry dust. Make sure you spur away from you cuz there's gonna be some dust flying off the pad in the last step! Good luck and post some pics of the progress everyone! --dave
Best Polish to restore Airstream ?? bgow 1969 Overlander 2 07-30-2009 11:04 AM
Old polishers take note Bradjun1 Cleaning, Stripping & Polishing 3 06-08-2005 04:06 AM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 07:15 AM
Partial Floor change winner Floor Finishes 12 07-22-2002 06:08 AM
Grades of vinyl... Andy R Floor Finishes 2 05-31-2002 11:47 AM
