Old 09-25-2013, 05:09 PM   #1
Hail on wheels
GeGe's Avatar
1992 25' Excella
Little Elm , Texas
When I polish I am getting black residue
I have removed the clear oat and I am now polishing. I am using a buffer and white diamond polish. I am getting black residue from the start. Should I continue or stop polishing. I have a lot of oxidation. I have been stopping and then washing with water and starting again. What am I doing wrong?
Gege
GeGe is offline   Reply With Quote
Old 09-25-2013, 05:17 PM   #2
Taylormade's Avatar
1978 31' Sovereign
black residue means it's working and that you've successfully removed the clear coat. Continue through it. Let the pad to the work... assume you're using a wool pad? Less is more when polishing, you don't need to load up the pad.
Ut Prosim
Taylormade is offline   Reply With Quote
Old 09-25-2013, 05:18 PM   #3
Hail on wheels
GeGe's Avatar
1992 25' Excella
Little Elm , Texas
I am using a terry cloth cover on my buffer. Wrong??
Gege
Old 09-25-2013, 05:45 PM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Hi....I think you should stop and read some polishing threads here on the Forums. You will wear yourself to a frazzle the way you seem to be going.
Old 09-25-2013, 05:49 PM   #5
Taylormade's Avatar
1978 31' Sovereign
Yes. Assuming you're using a 7" angle grinder type polisher, run over to Harbor Freight and grab some of their tuffer buffer wool pads. I bought like 5 or 6. Then put about a nickel sized amount of polish on the pad, apply it to the trailer and spread it out just a bit before turning it on.
I'll say this: that stuff works well, especially for touch ups, but because of it's liquidity, it makes a HUGE mess. It's also cost prohibitive unless you have a hook up. Look into the NuVite line of paste polishes. They're worth their weight in aluminum.
Ut Prosim
Old 09-25-2013, 07:44 PM   #6
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
GeGe...like others have said...switch to wool bonnets. If you are using one of the inexpensive car buffers like they sell at Walmart, that will not get through the aluminum oxide on your trailer. You will need, at a minimum, a rotary polisher that can be had at places like Harbor Freight for under $50. Velcro wool bonnets work great. As far as washing...water will not help. Your buffing pad should take most of the black off; but, you will have to clean your pad with a pad rake to keep it from getting caked up. Between a second buffing you will notice some black residue on your trailer...especially around the rivets. This should be cleaned with mineral spirits or corn starch. Then rebuff if needed.
Indiana, PA
TAC PA-5
WBCCI 4871
Roadrunner is offline   Reply With Quote
Old 09-25-2013, 08:41 PM   #7
TWaugh's Avatar
1969 25' Tradewind
1971 18' Caravel
Images: 8
Yep, there are a lot of good ideas on the polishing threads and a lot of folks with good advice and techniques.
Here is just one example of a technique. This is part 3 assuming you have prepped the surface....
FYI - all 5 parts to this video series are on youtube
Tom
Res nolunt diu male administrari.
WDCU Unit #170
Air #7085
TAC VA-4
WBCCI #2641
VAC
71 Caravel
69 Tradewind
My YouTube Channel
TWaugh is offline   Reply With Quote
Old 09-25-2013, 10:42 PM   #8
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
I just started using the White diamond, and yes - after shaking the bottle you kind of have to be careful where your aiming it or it will burp and splatter onto places you don't want it. It will also spit when you snap the lid shut. I am using a car buffer with a wool pad but I am now interested in the Harbor freight pads. With our 70' model- I think I polished it about five years ago, and am now doing it again. With the White D, you can almost do a small area (1 foot) and then hand polish it to a shine...but you can see the oxidation being polished back into the surface, or at least thats what it seems like to me. So I will wipe up last with Kerosene (not thinner)...Thinner will really dry out or burn your skin to a certain degree... whereas Kerosene stays supple longer and does the same thing if not better than thinner and is not as harsh...plus it is cheaper by the gallon. Wipe that black stuff away and keep polishing and good luck.
Also with the White D I seem to be coming out with more of a swirled finish as can be seen in the suns reflection.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 09-26-2013, 05:07 AM   #9
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
When you graduate from the rotary polisher the only thing that really removes the swirls is a cyclo polisher. Polishing is the "gift that keeps on giving..."
Indiana, PA
TAC PA-5
WBCCI 4871
Old 09-26-2013, 07:51 AM   #10
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
yes... the polishing work never ends if the trailer is stored outside.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 09-26-2013, 08:29 AM   #11
ALUMINUM OBSSESSION
1993 34' Limited
Hamilton , Ontario
If you go on U-tube, there is a site that shows you how to polish your Airstream. Search (How to polish Airstream) It's real good!!
william Haym is offline   Reply With Quote
Old 09-26-2013, 09:14 AM   #12
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Vintage Trailer Supply also has a fairly good document available online about polishing.
Lynn
WBCCI 21043
Old 09-29-2013, 09:59 AM   #13
Hail on wheels
GeGe's Avatar
1992 25' Excella
Little Elm , Texas
Thanks so much. Learned a lot by watching all the videos. I learned I was doing it all wrong. This is a big help. Ths
Gege
Old 09-30-2013, 06:14 PM   #14
Hail on wheels
GeGe's Avatar
1992 25' Excella
Little Elm , Texas
Thanks so much for everyone's advice. Headed to harbor freight
Gege
Black Water Flush Blocked ElliotA Plumbing - Systems & Fixtures 6 04-01-2017 06:26 PM
Combining black and gray tanks? trvler Waste Systems, Tanks & Totes 72 01-30-2012 11:36 AM
Help! Faucet water is black! Skatiero Water Heaters, Filters & Pumps 11 10-14-2011 08:51 AM
Black water flush system mjayjensen Waste Systems, Tanks & Totes 4 07-10-2011 05:21 PM
Noobie black water question pappy19 Waste Systems, Tanks & Totes 9 05-25-2011 09:52 PM
