Old 09-18-2007, 06:09 PM   #1
Tidal's Avatar
1972 31' Sovereign
Cordova , Tennessee
What's the best way to polish between letters?
The spaces in between the raised "AIRSTREAM" letters are posing a polishing challenge. Anyone have a simple fix? I'd prefer not to have to remove them. Thanks!
Tidal is offline   Reply With Quote
Old 09-19-2007, 07:35 PM   #2
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
If I remember correctly, I think that the Eastwood Corporation has felt tips of various shape which fit on Dremel tools. I considered using them when I had one of their catalogs but never got around to ordering them.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 09-20-2007, 05:26 AM   #3
87MH's Avatar
1978 31' Sovereign
Images: 292
If they are original, I would not even think of removing them. My front letters were already riveted in place, so I just drilled them out and polished the smooth surface. On the rear letters under the rear window (which were held in place with the original rear mounts) a 4" diameter circular buffing cloth designed to be used with a drill was purchased. I picked the buffing tool up at O'Reilly's Auto Parts. It is comprised of about 20 layers of duck cloth loosely stitched together. I purchased the thinnest one I could find (there were several thicknesses from which to choose) and was able to do an acceptable job with the drill. I also tried a 2", a 3", and a 6" diameter, but the 4" worked best. In all honesty, from 5' out you cannot even notice anything between the letters the cyclo cannot get to. I would hesitate to use a buffer too close the the letters for fear that the rear mounts would shear if the wool bonnet bumped a letter in the wrong place.
The cloth becomes "flexible" when pushed against the surface radially. A very slow speed works best.
The circular cloth buffing tools were also used on various places on the LPG tanks. The Propane/Butane tanks had a lot of deep scratches. I wet sanded them with 120, 220, and 400 grit, then compounded with F-9, F-7, and C. S was used with the cyclo on areas I could get to.
For the most part I found that compounding with S was a waste of time, as the 7" wool bonnets were unable to finish the surface with anything beyond "C" grade Nuvite. Wool bonnets, in my experience, always left a "3-D Hologram" which had to be removed with a cyclo.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 09-20-2007, 07:14 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Before you go and buy new toosels. Try hand polishing with some rags. It's not that bad.
Lumatic is online now   Reply With Quote
Old 09-20-2007, 08:24 PM   #5
Tidal's Avatar
1972 31' Sovereign
Cordova , Tennessee
Thanks everyone, great info!
How Do You Polish Around Letters? JohnG Cleaning, Stripping & Polishing 7 01-08-2014 03:27 PM
Airstream Letters 75 Sovereign ostapbender Cleaning, Stripping & Polishing 3 08-22-2007 05:24 AM
Looking for letters FrankR Our Community 6 10-14-2002 06:16 PM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 07:15 AM
