07-18-2010, 07:27 AM
1976 31' Sovereign
Springfield
, South Carolina
What year did they start clear coating streams
Just got my first trailer, 76 Sovereign and it could use exterior cleaning and in researching I keep reading about removing clear coat. I am thinking early 80s was when the clear coat craze hit the automotive world???
Anybody know on Airstream when it started?
07-18-2010, 07:47 AM
Corona
Airstream clear coated the trailers, as an option, if I remember correctly, in 1962.
In 1964, the clearcoating became standard.
Over time, the formulation changed, more than once.
07-18-2010, 10:25 AM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
I believe it was still an "option" in 1964 - I've seen some with and some without. Could be that it was standardized in the CA plant before the OH plant.
Shari
07-19-2010, 10:03 AM
Oswego
Clear Coat confusion???
Brand new to the Forum! After 15 years of dreaming and absolutely wearing out my SOB, bought new in '93, I found the deal I was looking for quite unexpectedly and suddenly while on vacation in my SOB! I got an 07 Classic 30...BARELY used, then stored in a barn for 2 years, due to illness. Inside is pristene. Outside is dirty and contains several "garage boo-boos. Thus my question: I have read and read this forum this week and am unclear. I think my unit is clear coat paint and not plasticote...right? If it is paint, what kind? Enamel, laquer etc. If it is paint, can it be finessed exactly like a car, using the same products?
Thanks, and I look forward to participating in this forum for many years to come!
07-19-2010, 10:18 AM
1967 26' Overlander
Winston Salem
, North Carolina
Hi,
Welcome to the forums.
Your unit has the clear coat applied at the factory (Alcoa).
Originally the Airstream factory would spray the plasticote on the skin after completion of the shell.
Good Luck
Greg
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
07-19-2010, 10:34 AM
1961 16' Bambi
Jacksonville
Andy,
Does that mean that my '61 bambi is probably not clearcoated? I can't visually tell if it is, and I have tested it with a stripper.
Brian
07-19-2010, 11:06 AM
Corona
Airstream's clear coat (plasticote) is specially designed to bond to aluminum.
The forulation has changes over the years, but the purpose is the same.
Automotive clear coats, of any kind, "WILL NOT" bond properly to aluminum. After it ages about 2 to 3 months, it can be peeled off as though it was cellophane. Even the wind will peel it off when traveling.
Also, "NO" etching of any kind is needed with the old clearcoats.
07-19-2010, 11:41 AM
1977 31' Sovereign
1989 34' Excella
Johnsburg
2007 Airstreams were made using from precoated sheet aluminum that is applied on the production line at the Alcoa plant. The top sheet is precoated white and the sides were clear. The parts that are stretched to form the ends are also precoated before Airstream does the stretch forming. As previous posters stated, anything before 1962 was made from Alcoa Alclad aluminum laminate and was not coated. My 1963 is made with Alclad and was not coated. For about $1 per foot they could have ordered the plasticoat option spray painted on at the Airstream factory.
07-19-2010, 11:48 AM
Oswego
So what is used on newer AS? I understand it is not Plasticote.
07-19-2010, 12:18 PM
1977 31' Sovereign
1989 34' Excella
Johnsburg
It is proprietary to Alcoa but I believe it a polyester based polymer. It is cured on line.
07-19-2010, 02:41 PM
Oswego
What would you use for touchup on chips & scratches then?
07-19-2010, 03:51 PM
1956 22' Safari
Conifer/Evergreen
If your trailer never had clearcoat, then it will be a uniform dull gray color overall. This photo shows our '56 Safari which was never clearcoated. Notice the even grey appearance of the skin. If yours had clearcoat that has failed, it will have a more splotchiness where the clearcoat has deteriorated and the oxidation has progressed unevenly over time. It will have a "peeling sunburn" look to it. This photo shows our '64 GT with peeling clearcoat & resulting splotchy oxidation, before it was polished.
The easiest way to test to see if you have clearcoat is to take a plain white t-shirt scrap, put a tiny dab of toothpaste on it and gently rub where you think the clearcoat is on your trailer (in an inconspicous place). If it turns black, there's no clearcoat...if not, you have clearcoat protecting the aluminum. The bare aluminum will turn the spot jet black...not just dirty.
Most likely, your '61 Bambi wasn't clearcoated...
Shari
09-05-2010, 09:33 PM
2003 22' International CCD
1977 31' Excella 500
1966 26' Overlander
Shelton
'03 CCD clearcoat????
Is my '03 22ft. CCD International clearcoated and what is the best method to remove it? Will the newer AS's polish up like the old ones? Thanks, Airstray
09-06-2010, 05:37 AM
1977 31' Sovereign
1989 34' Excella
Johnsburg
The newer Airstreams use an aluminium sheet which has a brushed mill finish on it before it is clear coated on the Alco line. The old units were made from a laminate aluminum sheet called Alclad and was originally intended for airplanes. It has a pure aluminum exterior and ha heat treatable alloy 2024 interior. The mill finish on this sheeting was quite smooth and shinny. I found an unaged area in hidden area on my 1963. If you wanted to polish a new Airstream you would need to compound off the brushed finish which would take quite a bit of work. The new alloy will most likely not take quite as bright a finish and will dull faster due to surface corrosion, but I have not proven that. You should talk directly with Alco to be sure.
09-06-2010, 06:24 AM
1970 27' Overlander
Espanola
, Full Timer
Ours is Alclad type and it shines up real nice. There was clearcoat in small places around attachments, and also on the underneath shells. The the above is correct, the newer models have a sort of brushed finish to them. I doubt with any ease you will get a shiny finish without a lot of trouble.
09-06-2010, 07:54 AM
2007 31' Classic
holland
, Pennsylvania
my understanding on my 2007 is that it should be treated the same as a new car finish.hence just wash and wax.nothing like the old clearcoat on older airstreams.since new all i have done to mine is the same carwash i use on my truck and it looks brand new.alcoa tested this finish in the hot fla sun and elements and their new technology should withstand most climates.on your unit i would hand wash and wax only.if it was sitting in a barn the dirt will come off after a few washes.
