Old 05-20-2002, 08:01 AM   #29
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
cleaners
I use armorall car wash for the vehicles, a soft brush extension pole for the motorhome, and a wash mitt for the car. This stuff is available at Walmart and is not too expensive. I wax the motorhome with liquid turtle wax, and it held up quite well for 5 months or so. I use Granitize on the Porsche which is very hard stuff. This older car has no clear coat. The trick for me has always to chamois the water off after the wash so you don't get too many spots or streaks.
I am presently using turtle wax tire wax a new product with UV protection in it, on my tires, it seems to work quite well.
I also use "Mothers Aluminum" polish which is ok, buit does not work as well as some of the more expensive polishes. I would love to try Rolite but have not yet, as I don't have a polishing machine. The Porsche is a 78.
Old 05-20-2002, 08:08 AM   #30
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Re: Soap
Originally posted by Cat
Ok...what is Walbernizing..I'm 'new'...
Cat,
Walbernize is a product recommended by Airstream to help retain the shine and clear coat. You can find it at Walbernize.com or other Airstream venues. It very easy to apply and wipe off. It leaves your trailer very slick. Newer trailers use the Super Seal product.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-20-2002, 09:23 AM   #31
83Excella's Avatar
1983 27' Excella
Airstreamville , Kansas
Thumbs up
Alan,
NICE Porsche.
John
83Excella is offline   Reply With Quote
Old 05-21-2002, 02:33 AM   #32
Cat
Cat's Avatar
Mukilteo , Washington
Images: 8
Send a message via Yahoo to Cat
Cleaning
Alan,
more on cleaning later...i'm just signing off.. ....but THAT's a "930".isn't it.(affectionately known as..)..?
BTW..my son says, "No OLDER than a 77 Mum"...wait till he sees yours...am I correct? is it a '930'..?
.....Cat
(sorry to be 'off the mark' here Webbie...just couldn't help myself. I'll try not to do it again.)
*Cat's Vardo "Bear" (1981-32ft.Excella)
http://autos.groups.yahoo.com/group/RoyalTrailerTrash[/u] to meet good people in good Parks[/i]
Cat is offline   Reply With Quote
Old 05-21-2002, 03:07 AM   #33
Cat
Cat's Avatar
Images: 8
Cleaning Agents
ok...i just went to AirstreamDreams.com, and got the 'skinny' on the care of our (affectionately known as "aka" ) "TinCans"... Here it is in its entirety:
Plasticoat can lose its protective capabilities due to aging or bleaching by the sunís ray and begin to wear thin causing chipping or peeling. Plasticoat is not a permanent finish and its life expectancy depends upon several factors such as the environment, weather, atmospheric conditions, salt air, road salt, industrial fall-out, and how well the trailer or motorhome is washed and waxed. It is extremely important that the plasticoat is reapplied to an area that has chipped or peeled to prevent oxidation from occurring. Oxidation is permanent and is impossible to remove. [Actually, oxidation is possible to remove from older units, but it is virtually impossible to remove from newer coaches with a textured and thinner skin.]
Cleaning the exterior of your trailer or motorhome should be done in the shade or on a cloudy day when the aluminum skin is cool. Oil, grease, dust and dirt may be removed by washing with any mild non-abrasive soap or detergent. Cleaning should be followed by a thorough clean water rinse. Spots and streaks may be prevented by drying the unit with a chamois or soft cloth. When washing or polishing always wipe with the grain of the metal. [The aluminum on older units does not have a grain.] After cleaning and drying, use a high grade, non-abrasive automotive past or liquid wax. This will increase the life of the finish, especially in coastal areas where the finish is exposed to salt air, or in polluted industrial areas. It will also protect the shell from minor scratches and make subsequent cleaning easier. Wax should normally be applied every three to six months.
It is important to remove sap, seeds, gum, resin and asphalt as soon as possible. [Donít forget bird droppings!] Sunlight and time will harden these materials making them almost impossible to remove without heavy buffing. If asphalt remains on the trailer or motorhome after washing, use a small amount of kerosene on a rag and wipe the spots individually, being careful not to scratch the finish. Bugs should also be removed as soon as possible because their acids will eat into the coating.
For small areas of damage to the plasticoat finish or where oxidation is beginning to occur, remove all traces of the coating with a high grade lacquer solvent then thoroughly clean the aluminum with an aluminum cleaner. Then respray the area with clear plasticoat. [Spray-on plasticoat is a clear acrylic spray and does not match the factory-applied plasticoat. It is a different color and does not go on as smoothly.] All items needed for these minor repairs to the exterior shell are available at your authorized Airstream dealer. For extensive refinishing we recommend that you contact an authorized Airstream Service Center or the Factory Service Center.
NOTE: The cleaner recommended by Airstream is Walbernize Super Seal and Glaze for 1984 and newer models which have been plasticoated, plus units that have been replasticoated. [The accurate name of this product is Walbernize RV Super Seal.] For units built prior to 1984, Airstream recommends Walbernize Cleaner and Glaze. [The accurate name of this product is Walbernize Cleaner, Polish and Glaze.] These products are available at your authorized Airstream dealer. [Or from us... Shop for Walbernize ]
That's the end of it... I do recommend the AirstreamDreams.com site to anyone who owns an Aluminum rig.
...peace..........Cat
Old 05-21-2002, 07:06 AM   #34
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
No- its a 911SC, model built from 78-83. The first year for the 3.0 liter engine, and wider rear fender style. Mine is upgraded to 16" wheels, and has optional front and rear spoilers, and stone guards on the side. This paricular model is known to be quite "bullet proof" and although has a few documented mechanical glitches, they almost never break. Can go 300,000 or more miles with minor maintenance. I should say 300,000 or more quite fun miles.
Sorry Airstreamers- my other passion has been porsches, since I first rode in a 356 back in the late 60's.
As for the above info, has anyone had any luck with re spraying or applying small spots of plasticoat? I have a few spots on the roof that could use that- while most of my coach has a nice coat on it.
Old 05-21-2002, 05:45 PM   #35
Cat
Cat's Avatar
Images: 8
ALGAE...Help
Alan...
I don't have time right now to read and look for what I wanted to refer you to for the roof of your Rig...
but I think it's with AirstreamDreams.com... Or ..call 1-800-877-7911 and ask for Andy...tell him you're calling from the Forum...and ask your question...if you don't get the info off the AirstreamDreams site.
I'll check it over later...
Still haven't had anyone respond to my previous 'post' about what I should use to b est remove the ALGAE from the Exterior skin...??????????????????
Old 05-23-2002, 07:27 AM   #36
83Excella's Avatar
1983 27' Excella
Walbernize
I use Walbernize super seal on my Excella and the trailer looks new when I am done, I highly recommend using it to any Airstream owner. However, DO NOT use it on the blue stripes or any older decals it will cause it to shrink and crack (learned from experience).
John
Old 05-24-2002, 01:54 AM   #37
Cat
Cat's Avatar
Images: 8
Walbernizing
Hi Jack. so THAT's what happened to my decals... The big ones that encircle the whole rig around the middle? Yup...they have shrunk...and they sure have CRACKED... I have that on a "round-to-it" list to replace. So, when you Walbernize the fuselage, you just skip the decals...and then what do you use to protect the decals.??
& BTW...Does anyone know where can you get new decals?
............Cat
Old 05-24-2002, 07:03 AM   #38
jcanavera's Avatar
Fenton , Missouri
Images: 143
Hi Cat. John made the comment about the decals not me.
This is the first I have heard something regarding the Walbernize product having a bad effect on the A/S decals. I do know that any decal will weather over the years although I have never had any deteriorate on any brand of trailer to the point of either looking badly or needing replacement.
John, is it possible that A/S had some problems with decals at one point? Most of us are aware of the clear coat problems that struck the mid 90's units. That only got resolved when they switched to precoated panels from Alcoa.
Maybe the problem with the Walbernize product and decals only covers a certain period of time? Or could it be environmental based on where you store your trailer. Lots of nasty things in the air in some locals.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-24-2002, 03:11 PM   #39
83Excella's Avatar
1983 27' Excella
The blue stripe decal that goes around my Excella is old and weather'd, probably the original and the ingredient(s) in the Walbernize caused it to shrink and crack, I havent tried it on a newer decal to see the results but Cat & I have learned the hard way not to put it on decals.
fyi, there are no ingredients listed on my bottle of RV Super Seal, it does say it is combustible, use with ventilation, causes drying of the skin, etc... I wonder if there are any petroleum ingredients since it dries your skin, is flammable, removes traffic film, road oil or tar??? I will have to email them and ask.
John
Old 06-11-2002, 05:24 PM   #40
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
The answer you have been looking for????
I just got my Blue Beret from the mailbox and it contains the answer to the burning question, what do I wash the trailer with?
This is quoted from the article in the June 2002 Blue Beret by David Schumann, Director Service, Parts, and Warranty Administration at Airstream. Page 45.
Plasticote- This clear acrylic coating was used to protect the aluminum skin from oxidizing. This was used prior to 1999 models or on units that have been stripped and clear coated.
This can be maintained by washing the trailer and then using Walbernize Super Seal and Glaze.
Starting in 1999 trailers were built with metal that was coated with PF8A0-1 Fluorocarbon Clear Paint. This finish is applied by Alcoa before Airstream receives the metal used to build the trailers.
This finish is durable and can be easily maintained by washing with a 5% solution of any common detergent and then waxing. Walbernize products work well for this. Never use harsh solvents on either of these finishes.
Jack, I guess your persistence paid off. Someone felt there was enough interest in the issue to write an article.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 06-12-2002, 06:57 AM   #41
jcanavera's Avatar
Fenton , Missouri
Images: 143
Brett,
I saw the article yesterday. Thanks for copying it to the forum. I found it interesting that they finally noted what the new clear coat is. I'll be interested in seeing how it holds up over the years. It's too soon to assume that the final answer is in.
I use Super Seal and it really provides a slick surface.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-12-2002, 11:28 AM   #42
83Excella's Avatar
1983 27' Excella
I have pasted that information here fyi from the WBCCI website.
John
(quote)
This and That
Plasticote- is a clear acrylic coating used to protect the aluminum skin from oxidizing.
This was used prior to 1999 models or on units that are_stripped and recoated.
This can be maintained by washing trailer and then using Walbernize Super Seal and Glaze.
Starting in 1999 trailers were built with metal that was coated with PF8A0-1 Flourocarbon Clear paint.__ This finish is applied by Alcoa before Airstream receives the metal used to build the trailers.
(end quote)
What is your Brake Controller of Choice? overlander64 Brakes & Brake Controllers 71 11-29-2008 08:40 AM
Some towing Q & A for newbies femuse Towing, Tow Vehicles & Hitches 3 08-24-2004 08:05 AM
trailer wiring Cruiser Electrical - Systems, Generators, Batteries & Solar 4 09-02-2003 01:43 PM
Getting Close! kamadeca Our Community 48 02-05-2003 08:56 AM
Trailer Listing To "Street Side" montanaandy Axles 4 06-07-2002 12:15 PM
