03-18-2005, 06:58 PM
What to do with this exterior
My dad and I are thinking of restoring the exterior (maybe polish) of our 1975 Airstream. Everything about it is great, but the exterior is starting to show its age.
So the loaded question is, of course, what do you experts recommend? I have read a lot of the forum, but there seems to be different approaches depending on the condition. I am probably going to be doing the bulk of the work, and am familiar with car & truck polishing.
I have attached a bunch of pictures of our trailer.
03-18-2005, 07:00 PM
There are also two spots were some odd polishing or buffing was done by the PO. We tried some Wally polish, but that didn't really do anything. See pics.
03-18-2005, 08:47 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Looks to me like you have about 3 choices: Strip and Polish, Strip and re-Clearcoat, or strip and Paint it Silver. Something I have observed but not quite sure of the reason why, is that the corner segements seem to have more problems with the clear coat than the rest of the shell. I have some that actually have hand prints in them. These segements on my unit were replaced and I can only assume that when they resprayed them (probably with a spray can from the looks of it) they did not clean them properly prior to the respray.
Aaron
WBCCI #XXXX AIR #2495
03-19-2005, 04:42 AM
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County
, New Hampshire
My 75 is in a little better shape. I'm going to polish what is there to see how it comes out. But from my test panel I did Thursday it looks like I'll be stripping and going for the polished look sooner rather than later.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
03-19-2005, 11:48 AM
a.k.a. Ambassador Tim
1960 28' Ambassador
Northern
My trailer was peeling the clear coat and very splochy in places. I had no intention on every polishing.
So I just stripped it with Bix stripper from home depot. It made the outside very even looking and cleaned it up nice.
Of course, after that was done it only took another 120 hours to polish so I thought.. why not.
03-21-2005, 12:40 PM
Well, we have decided to strip and polish.
A couple of questions.
1) What is the best stripper to use if you're going to it yourself, outside behind the house?
2) Is there a place where one can buy an entire polishing "kit", or do you buy the parts and polishes as you go?
03-21-2005, 07:03 PM
1976 31' Sovereign
Chandler
, Oklahoma
Look on ebay at the little 1966 Caravel for sale by the guy in Broken Arrow, Oklahoma. He does restoration of classic planes and now Airstreams. That seems to be all he does. You may have luck emailing him with your polishing questions since it seems most of the questions asked were not about what he had for sale but what he suggested people use on their Airstreams. He seems to have a good sense of humor about all the questions.
03-21-2005, 07:26 PM
There have been lots of discussions on strippers. I chose Napier's RemoveAll 210 because it is safer (less toxic). I've only done a small section, but it worked great for me. I could not find it locally, so purchased online from www.dtep.com
Good luck with your project! LAS
03-21-2005, 10:48 PM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
Believe Herb...I've seen his trailer!
You can too if you join us at the 2005 Rocky Mountain VAC Rally!
Shari
03-21-2005, 11:16 PM
I have used the Nuvite before, (when I used to own an "unpainted Argosy").
It worked well.
It will take you LONG time but do not stop halfway through it. Nothing looks worse then that.
Good luck.
03-22-2005, 08:09 AM
Originally Posted by Ferroequine
There are also two spots were some odd polishing or buffing was done by the PO. .
I think those spots are something else. My trailer has a spot like that--apparently (from what i can guess from old receipts dating back to the original owner) it was a repair in the skin. What do they call that stuff--Bondo? In my case, the awning was apparently ripped out of the skin at some point. Ouch. I'll attach a pic. I'm pretty sure it will never buff out, but please tell me if i'm wrong!
'77 Overlander: 'Betty'
03-22-2005, 09:38 AM
1975 Argosy 26
1963 24' Tradewind
Seattle
Napier is great!
I really like the Napier. I bought mine from a local ICI Paints distributer. They call it Hydrostrip 502. I'm using it to strip paint from my Argosy. I think if it were even warmer (it calls for temps 70-90 degrees, it's only MAYBE 60 on a good day here in the NW). Spread it thick, and it just hoses off. Minimal smell, fairly "biodegradable" and won't cause you labortary rat cancer!
Marc
03-22-2005, 07:12 PM
Hmmm, is there a way to tell if it is bondo before starting a strip 'n polish? It would kinda suck having a shiny exterior and those "bald spots" on it.
03-23-2005, 12:45 AM
1960 28' Ambassador
Northern
Just custom cut a WBCCI sticker around it
03-24-2005, 12:30 PM
Well, I'm taking the plunge and am going to order some tubs of Nuvite and a Cyclo polisher.
So, how many 1 lb tubs of Nuvite F7, C and S polish do you guys think I might need? I have to order it into Canada, so multiple shipments get kind of expensive...
03-24-2005, 01:03 PM
1956 22' Safari
Conifer/Evergreen
On our 19-footer we used: 1 1/2-lb of the 'C' with the compounder
1-lb of 'F7' with the Cyclo-Polisher and
1-lb of 'S' for the final polish with the Cyclo-Polisher
You will then be using 'S' and maybe leftover 'C' & 'F7' to maintain the polish on an annual basis. So if you'd rather order it all at once, you might want another 'S' to get you by for a couple of years.
I would expect you 22-footer would take about the same, depending on your oxidation and satifaction levels. Keep in mind that each year you touch it up the overall polish will improve.
Shari
03-25-2005, 07:01 PM
1956 22' Safari
Conifer/Evergreen
This is as good as anywhere to post a note
to let everybody know I have finally
updated our website with a
Stripping & Polishing section.
Enjoy!
Shari
03-26-2005, 09:31 AM
Retired.
, At Large
Bondo and paint?
It looks like it was painted silver over some bondo, why not find a not-so-noticeable spot there one of these things are, and apply a little laquer thinner to it? If it is paint, it will pucker up and the paint will come off, revealing the bondo underneath. If that is the case, just touch up again with some silver paint, and you will be no worse off than you are now, except you will know what you have. If it doesn't come off, it may be where it was roughed up for the repair, and may not polish out.
03-26-2005, 09:46 AM
1960 28' Ambassador
Northern
How about pulling the awning mount off a little bit while you olympic rivet a square of aluminum for a patch. Then remount the bracket.
