Old 03-23-2005, 12:45 AM   #15
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Originally Posted by Ferroequine
Hmmm, is there a way to tell if it is bondo before starting a strip 'n polish? It would kinda suck having a shiny exterior and those "bald spots" on it.
Just custom cut a WBCCI sticker around it
-Tim
theVAP - Airstream Podcast
Old 03-24-2005, 12:30 PM   #16
Ferroequine's Avatar
1975 23' Safari
Calgary , Alberta
Well, I'm taking the plunge and am going to order some tubs of Nuvite and a Cyclo polisher.
So, how many 1 lb tubs of Nuvite F7, C and S polish do you guys think I might need? I have to order it into Canada, so multiple shipments get kind of expensive...
1975 Safari 23'
2004 Ford Expedition Eddie Bauer 4x4
Ferroequine is offline   Reply With Quote
Old 03-24-2005, 01:03 PM   #17
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
On our 19-footer we used:
1 1/2-lb of the 'C' with the compounder
1-lb of 'F7' with the Cyclo-Polisher and
1-lb of 'S' for the final polish with the Cyclo-Polisher
You will then be using 'S' and maybe leftover 'C' & 'F7' to maintain the polish on an annual basis. So if you'd rather order it all at once, you might want another 'S' to get you by for a couple of years.
I would expect you 22-footer would take about the same, depending on your oxidation and satifaction levels. Keep in mind that each year you touch it up the overall polish will improve.
Shari
Old 03-25-2005, 07:01 PM   #18
InsideOut's Avatar
1956 22' Safari
Images: 108
This is as good as anywhere to post a note
to let everybody know I have finally
updated our website with a
Stripping & Polishing section.
Enjoy!
Shari
Old 03-26-2005, 09:31 AM   #19
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Bondo and paint?
It looks like it was painted silver over some bondo, why not find a not-so-noticeable spot there one of these things are, and apply a little laquer thinner to it? If it is paint, it will pucker up and the paint will come off, revealing the bondo underneath. If that is the case, just touch up again with some silver paint, and you will be no worse off than you are now, except you will know what you have. If it doesn't come off, it may be where it was roughed up for the repair, and may not polish out.
Old 03-26-2005, 09:46 AM   #20
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
How about pulling the awning mount off a little bit while you olympic rivet a square of aluminum for a patch. Then remount the bracket.
-Tim
Old 03-26-2005, 09:49 AM   #21
Vintage RV
1959 24' Tradewind
Atascadero , California
Images: 14
Send a message via Yahoo to plowboy
Cool
I've been using metalwax and have been quite happy with the results. Unlike Nuvite and rolite products, which leave a black residue which is hard to remove, metawax cleans up with plain soap and water. The owner of the airstream on the metalwax website said he uses cornstarch, which is another option.
Go to metalwax.com
I've doon most of the trailer by hand, but a comercial random orbital polisher works well also.
As soon as I can figure out how to reduce the size of the trailer pics I'll post them.
What ever you decide just take your time and enjoy the results.
Paul
plowboy is offline   Reply With Quote
Old 03-26-2005, 01:19 PM   #22
sovereignrwe's Avatar
1972 31' Sovereign
Oakdale , Minnesota
Paul...after looking at the metalwax website, I think you are using this product for polishing, not for stripping. Is this correct? If so, what did you use to strip?
Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
sovereignrwe is offline   Reply With Quote
Old 03-27-2005, 02:19 PM   #23
Polishing update
Enjoy!
Shari
Wow Shari! Thanks for the website update. What a beautiful job. We're waiting for decent weather to tackle our '78 31' Sovereign. I know it is going to be a HUGE job, but photos such as yours are real incentive and show us our goal. Thanks again. Gale
windyg is offline   Reply With Quote
Old 03-27-2005, 06:05 PM   #24
Vintage RV
1959 24' Tradewind
Images: 14
Mark and Kimber- Our tradewind is a 1959 which didn't have a clear coat. Airstream didn't start clear coating until some time in the '60's. Check the website for threads on clear coat stripping, I'm sure you'll find what you need. Good luck!
Paul
Old 03-28-2005, 07:02 AM   #25
1972 31' Sovereign
Oakdale , Minnesota
Thank you for responding, Paul. Good information.
Mark
Old 03-31-2005, 12:20 PM   #26
1975 23' Safari
Calgary , Alberta
Well, after trying some paint thinner on that funky spot, the rag started turning black and the metal started to come showing through . I'm guessing the PO had started some polishing / sanding, and just marred up the plasticoat. Excellent.
I'm going to place an order tomorrow with Perfect Polish for a bunch of polish and a Cyclo set. I should be able to buy a compounder & aircraft stripper locally here, since there is a huge airport & associated little industries. Anything else I should know about?
Planning for a "stripping party" on the May long weekend, if not sooner.
1975 Safari 23'
Old 03-31-2005, 12:34 PM   #27
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
If you have not already placed an order, check out
Cheapest price I have found and he'll give you a 10% first time discount.
Got my kit coming for $250 Free shipping...
Did you look at Por products for stripper???
http://www.winnerscircledetailingpro...?idCategory=35
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 03-31-2005, 01:11 PM   #28
1975 23' Safari
Calgary , Alberta
Yeah, I saw Winner's circle , but they don't offer free shipping to Canada, so it's the same for me.
Bringing stuff like caustic stripper across the border can be a real hassle too, so there are less headaches by sourcing something locally.
1975 Safari 23'
Basic exterior cleaning of a neglected trailer Andy R Cleaning, Stripping & Polishing 12 05-10-2013 11:03 AM
Sealant Products - Exterior & Interior Cat Leaks - Weatherstrips, Gaskets, Caulks & Sealants 21 02-12-2003 10:00 PM
Help!! exterior outlet cover stuck TheBigRedTruck Electrical - Systems, Generators, Batteries & Solar 8 06-28-2002 11:04 AM
Exterior Door Movement Action Doors & Locks 0 05-20-2002 03:07 PM
Exterior trim ALANSD Airstream Motorhome Forums 1 04-14-2002 07:53 PM
