Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 06-17-2015, 09:15 PM   #1
OklaOverland's Avatar
Tulsa , Oklahoma
What is this white stuff and how do I kill it!
I'm finding this white corrosion in several places around the outside. (Theres a ton of it on the roof!) If i spend enough time i can scrape it off with my finger nail but is there a safe and easy(er) way to deal with this. pic below
OklaOverland is offline   Reply With Quote
Old 06-17-2015, 09:27 PM   #2
reinergirl's Avatar
Hollis , New Hampshire
Show us pictures of the roof. It's either corrosion ( ie aluminum rust) or failed clearcoat, that would be unusual on a 1963 but not out of the realm of possibility .
reinergirl is offline   Reply With Quote
Old 06-17-2015, 09:39 PM   #3
Slowpoke
Gnorts's Avatar
2012 27' Flying Cloud
Portland , Oregon
That stuff next to the red lens in your pic looks like adhesive residue. If you can scrape it off with your fingernail, try a little goo-gone, or some paint thinner (goo-gone is just mineral spirits and perfume) and see if it cuts it. If you have a similar mess on the roof, it may be the remains of an old coating of roof paint of some sort...
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
Gnorts is offline   Reply With Quote
Old 06-17-2015, 09:46 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
You get yourself a "pig" or "cow" hoof. Trim to a "scraping edge".. And watch how good it works. Easier than getting a "MAN-icure"
If "clear coat" it should loosen with solvent like Lacquer thinner. If nothing dissolves it, it is likely corrosion.
Option one... Do nothing and say, "That aint corrosion, that is an Airstream Beard,, they are earned!
Option 2... Scrape or polish off the old "beard".... Polish whole shell. "Clear coat with NYALIC.
Option 3.... Paint it... Like this:
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-18-2015, 10:39 AM   #5
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
They were coated with clear lacquer back then that failed pretty quickly if not stored out of the sunlight .
dannydimitt is offline   Reply With Quote
Old 06-18-2015, 03:23 PM   #6
Tulsa , Oklahoma
Roof
Heres the roof. The guy i bought it from had it half way under some trees. The side in the shade doesn't have as much as this side.
Old 06-18-2015, 03:37 PM   #7
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Are you trying to keep it original. if not white rubberized roof paint might be the simplest solution.
Old 06-18-2015, 06:39 PM   #8
Tulsa , Oklahoma
I'd like to see the aliminum again.
Old 06-18-2015, 09:42 PM   #9
1979 23' Safari
Wayland , New York
Put a little paint stripper on a small spot and give it a few minutes to see if it bubbles up. If it does it's failing clear coat.
If it doesn't bubble up it may be where there was clear coat that has worn away over time. Causing uneven corrosion.
Get a small bottle of car polish . Give it a good rub for a while. If the cloth turns black, you're removing aluminum corrosion, and are on bare metal and polishing it slightly.
If it's chalky white it may be where clear coat started to fail and held water on the aluminum causing excess aluminum oxide formation. Generally a heavy polishing will remove most of it, but you may still have slight surface putting in the end. Can still be made to look good though, maybe just not enough to shave in.
Old 06-19-2015, 02:12 PM   #10
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
strip the coat with Aircraft or similar stripper. You can choose to polish then or use a good car type wax to make it look shinier.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 06-19-2015, 02:39 PM   #11
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
Clear coat still there on the shady side, gone on sunny side
I agree with what HiJoeSilver said. That looks like clear coat that has failed (like completely gone) in some places and still there in others.
Fortunately, aluminum oxide forms a protective coating that usually stops further corrosion. If you can get the old clear coat off, the aluminum should polish out.
Be aware that a trailer can be polished back to "original finish" aluminum look with lots less work than the purists put into their beautiful mirror finish jobs. I used a Cyclo with yellow wool pads (moderately aggressive). I had the entire trailer looking good with one pass in some places where the clear coat had been in good shape to maybe three passes where the aluminum oxide was really established. After all, the Cyclo was designed to polish aluminum airplanes.
I took these pics right after I finished polishing. Four years later, it could use a touch-up, but still doesn't look bad.
Name:	Curbside post polishing.JPG
ID:	241105   Click image for larger version
Name:	Streetside post polishing.JPG
Old 06-19-2015, 03:14 PM   #12
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I would love to see what it looks like now, after 4 years of exposure.
Stephanie
Old 06-19-2015, 09:38 PM   #13
1979 23' Safari
Wayland , New York
Mimi, that's a sharp looking trailer!
Old 08-15-2015, 11:23 AM   #14
Tulsa , Oklahoma
Which compound did you use? Nubrite? And did you use just one grade or several?
See my progress on Instagram @MonicaTheAirstream
Old 10-14-2015, 05:32 PM   #15
Tulsa , Oklahoma
Update. I used "Premium Stripper" from Home Depot and a plastic scrapper and removed all of it. I took some time but you guys were right.
White Stuff pawnguy General Repair Forum 1 04-30-2015 05:16 PM
Warm-white vs cold-white LED lights? aircampr Airstream Lifestyle 64 03-13-2015 04:31 PM
White fuzzy stuff wall covering Airperson Upholstery, Blinds, Walls & Interior Finishes 4 09-07-2011 06:22 PM
White powdery stuff that looks like bird poop whacksplat 2008 Safari SE 7 02-24-2010 11:36 PM
umbilical and kill switch boondockdad Electrical - Systems, Generators, Batteries & Solar 9 10-25-2008 04:05 PM
