Old 12-21-2015, 07:16 PM   #15
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi bobkatbry. Your vintage Trade Wind has a good case of southern exposure. The rain and humidity, and maybe sea breezes, will oxidize exposed aluminum pretty good. Arizona trailers don't have this as much. It appears your trailer has a pretty good body, no major dents or holes. That is worth a bunch.
My old Trade Wind was pretty bad too. I did find my pressure washer blasted some of the crud off. But pressure washing does drive moisture into areas where it shouldn't be. Mine dried out with no lasting damage.
I think restoring the exterior skins is one of the last things on a vintage trailer renovation. That moist environment may have caused subfloor and frame rot, which should be addressed first in my view. Possibly the axles and brakes need attention too. Then move on to plumbing and wiring. Then on appliances and interior renovation. Now you have a trailer that is sound and ready for the road. You can renovate the exterior at that time.
David
Old 12-21-2015, 09:58 PM   #16
1996 25' Excella
Tillsonburg , Ontario
Just to reinforce the point about oven cleaner! Oven cleaner is Caustic Soda (Lye; for us old guys!) Caustic soda dissolves aluminum!!!! Very quickly... and even if you don't get through the skin, the finish will be too rough to polish out.
I used to work in a Bakelite factory. They used caustic to remove baked on gunk from the process... One day someone put a gobbed up aluminum grain shovel in a drum of caustic to clean it! Gunk and shovel gone in 15 minutes!
JCW
JCWDCW is offline   Reply With Quote
What did I do wrong? Aluminum turns dull suddenly... ggoat!!! Cleaning, Stripping & Polishing 17 07-26-2012 05:07 PM
Nevr-Dull polish? Deluxe21 Cleaning, Stripping & Polishing 8 06-30-2010 10:28 PM
dull roof on 1986 31' sovereign Daryl Miron Roof 12 07-25-2005 12:37 AM
Make mine dull aluminum markdoane Cleaning, Stripping & Polishing 39 10-25-2004 10:38 AM
Dull walls and yellow plastic ends 74SovereignInt. Upholstery, Blinds, Walls & Interior Finishes 35 10-15-2004 12:57 AM
