Old 07-15-2008, 12:30 PM   #1
yourtown , anywhere
what is this and how do you make it go away?
I am looking at this '63 FC for possible purchase, but I am wondering if the skin can be polished back to a smooth shine.
Name:	flying cloud.jpg
bassface is offline   Reply With Quote
Old 07-15-2008, 12:35 PM   #2
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
that looks like what generally comes from a tree or bush rubbing in the wind. Yours looks like a rope did it. If it's not scratched, it comes out even easier than the normal corrosion.
Zep
Old 07-15-2008, 12:54 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
As I understand it the older Airstream were made of aluminum that was the same material through the skin unlike the newer ones that are clad like our money. You can polish an older trailer till you reach the other side if necessary.
Don't see any dents on this side so have at it.
2004 Excursion 4x4
Old 07-15-2008, 02:41 PM   #4
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
That won't polish up at all. In fact, the more you try, the duller it will get. You should pass on this one and let me have it.
In all seriousness, that FC will polish up and look like a new dime when you're done. Best of luck with your decision.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 07-15-2008, 02:57 PM   #5
1953 Flying Cloud
1953 Flying's Avatar
1953 21' Flying Cloud
West Sacramento , California
Images: 8
It will shine again....
My was way worse than yours. It will take a whole lot of time and I mean a WHOLE lot of time.......
Custom driver license Pet ID's.
www.petidforme.com/105
1953 Flying is offline   Reply With Quote
Old 07-15-2008, 03:17 PM   #6
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
The black rub marks will only go away with polishing though...there is nothing that will remove them and not the oxidation too, which would look about the same in the "desirability department" as the black spots.
Shari
Old 07-15-2008, 06:46 PM   #7
San Diego , California
I see that alot Im sure most Know but 4 thoughs that dont. DO NOT cover your AS with a tarp flapinging in the wind. But yes it will polish out very nice.
got polish is offline   Reply With Quote
Old 07-15-2008, 08:49 PM   #8
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Ditto the above. I found my tradewind sat in a field. Trees grew up around it and the branches moved back and forth and back and forth for 20 years causing similar marks. They come out with elbow grease. Folks recomend Nuvite, etc. but I also used No. 7 Polishing Compound and that works too, is cheap and available anywhere. I'm not saying it's the best but it works.
polish, skin
Do they still make these? toastie Lights - Interior & Exterior 8 12-19-2007 09:41 AM
need to make a model nevisstudio Interior Restoration Forum 9 07-15-2005 08:37 PM
OK, Do they make? sjptak Our Community 14 07-01-2003 09:24 AM
They don't make them like they used to femuse Our Community 23 04-29-2003 07:15 AM
