Old 06-11-2016, 09:33 PM   #1
1973 31' Sovereign
Prescott Valley , Arizona
What is this?
At first I thought this was a problem with the clear coat. I striped this with the stuff from vintage trailer supply left on for 30 min the first time 1 hour the second. Polished with mothers and a buffer. Do you think this is removable?
RebekahJoyce is offline   Reply With Quote
Old 06-13-2016, 09:05 PM   #2
TinSheets's Avatar
2016 30' International
Grand Junction , Colorado
Photos don't load for me....
Wine Consultants on the move:
www.tinsheets.com
www.tinsheetstothewind.com
TinSheets is offline   Reply With Quote
Old 06-16-2016, 09:10 AM   #3
1973 31' Sovereign
Old 06-17-2016, 06:25 AM   #4
TinSheets's Avatar
Disclaimer: I am new to airstreams, and have exactly 0 experience with older airstream finishes.
Now that's out of the way I'd say one of two things:
1. That there was clearcoat still there and the mothers cut the clear coat. Easy solution is a finer polish to remove the haze. From what I understand about older airstream clearcoats, this is the less likely option.
2. Too much mothers was used too fast. Take a smaller amount and work a smaller area and see if you can bring up a shine.
Now another option would be to find a good fine grade polish and try a small area and see if you can remove the haze- try by hand first, and if you can then switch to the buffer so you can move a little faster. At least that's what I'd say if this were a car finish.
www.tinsheets.com
