Old 07-28-2011, 12:17 PM   #1
1985 31' Excella
Rigaud , quebec
What is best order.
I am starting to work on my 85 Excella 31ft. I want to strip the old clear coat, fix leaks by re caulking then polish. I'm thinking the order should be as follows.
1) Strip clear coat
2) Remove old caulking
3) Polish
4 Re do Caulking
My reasoning is that if I remove the caulking first when I strip the water will enter into the trailer and if I re caulk before polishing the Polisher may interfere with the new caulking. I will be starting on the roof as it needs some attention. Thanks for your help
Dave
dluker is offline   Reply With Quote
Old 07-28-2011, 02:39 PM   #2
Southwestern , Ohio
Sounds good to me!
Something to be aware of is that a 1985 trailer will not take as good a polish as pre-1980 trailers because the factory stopped using Alclad aluminum (.005 inch of pure aluminum over aluminum alloy sheet) around 1982. Nor will the aluminum surface resist corrosion as well. You may want to consider having it re-clear-coated.
Nuvite-F is offline   Reply With Quote
TAC - Embroidered Shirts robandzoe Other Clubs 22 04-16-2012 01:40 PM
Classic vs Classic limited Flying Gypsies 2006 - 2010 Classic (all lengths) 13 10-15-2011 06:37 PM
Axle upgrades Darkspeed Axles 12 05-11-2011 09:42 PM
Dometic light RM3862 gone, what to order and where? Silver Otter Refrigerators 3 04-24-2011 09:19 PM
replacing tub and sink in order bwaysteve Sinks, Showers & Toilets 8 02-16-2011 07:11 PM
