What is best order.
I am starting to work on my 85 Excella 31ft. I want to strip the old clear coat, fix leaks by re caulking then polish. I'm thinking the order should be as follows.
1) Strip clear coat
2) Remove old caulking
3) Polish
4 Re do Caulking
My reasoning is that if I remove the caulking first when I strip the water will enter into the trailer and if I re caulk before polishing the Polisher may interfere with the new caulking. I will be starting on the roof as it needs some attention. Thanks for your help
Dave
