Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 09-15-2009, 04:09 PM   #1
Profile:  1967 24' Tradewind
Redding , California
Question What chemicals are NOT safe w/aluminum?
Getting ready to cleanup the window frames and want to know what common chemicals NOT to use to dissolve the adhesives from old weatherstripping. I'm talking commonly available items such as acetone,lacquer thinner and such. Hate to be trying to do some good and do some permanent damage!
SilverHoot is offline   Reply With Quote
Old 09-15-2009, 04:29 PM   #2
mello mike's Avatar
Profile:  1972 31' Sovereign
Phoenix , Arizona
Images: 14
Simple Green cleaner. It will ruin the finish on any kind of aluminum.
Sterling - 1972 Sovereign Intl (RB)
Eddie - 2003 Ford Excursion (6.0L PSD)
Prodigy Brake Controller / Equal-i-zer Hitch / Honda EU2000i x2
Airstream Life Contributor
WBCCI 4CU #5661/AIR #5661
My Refurb Blog: UPDATED!!
http://mellomikesairstreams.blogspot.com/
Part wanted: 70s Kitchen Counter Unit
mello mike is offline   Reply With Quote
Old 09-15-2009, 04:51 PM   #3
Kevin245's Avatar
Profile:  1976 31' Sovereign
Rock Hill , South Carolina
We use acetone to clean aluminum routinely. It will damage some clear coatings, but it won't hurt the aluminum.
Regards,
Kevin
Experience can be a difficult teacher...You usually get the lesson first...And the instruction afterwards...
Old 10-06-2009, 03:48 PM   #4
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Images: 13
I'll second this one! Just did it a couple weeks ago. It's environmentally safe after all - or so I thought. Not plasticoat environmentally safe.
I sprayed the belt line. The went around the trailer right after with a carwash mitt. It left milky streaks in the coating where it ran down the side. We were able to wax most of it out with a brand of wipe on/off Turtle wax and a microfiber cloth. You wouldn't really see it but I can....
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 09-15-2009, 04:45 PM   #5
Thanks Mike,
Must be some chemists or metals experts out there that know in general terms which chemicals will ruin aluminum then we could check the ingredients if available or MSDS info. Wonder what the ingredient in Simple Green is that is harmful to aluminum? Just checked the label on Simple Green and it says do not use on plastic, leather, suede, unfinished wood, opals or pearls. Nothing about aluminum, so an unsuspecting person like me, but one that does not ask, could cause problems for themselves.
Old 09-15-2009, 05:30 PM   #6
mello mike's Avatar
Phoenix , Arizona
Images: 14
Originally Posted by SilverHoot View Post
Thanks Mike,
Yeah, I sprayed some on my kitchen countertop and some excess spray got on my aluminum backsplash. Fortunately, it's at the very bottom and you don't see much but the spots won't come out. Others on this site can attest to this, too.
Old 09-15-2009, 06:05 PM   #7
Wingeezer's Avatar
Profile:  2005 30' Classic
Burlington , Ontario
I used to be the plant engineer at a major railway overhaul shop. We had huge
steam-heated caustic vats the size of swimming pools for cleaning baskets of engine parts & such.
If anyone made the mistake of putting any aluminum items in the caustic vat, they would soon vanish!
Brian
(PS I suspect Simple Green may be mildly alkaline (Caustic), not sure though.)
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 09-15-2009, 04:58 PM   #8
Profile:  , Minnesota
Images: 59
3M adhesive remover.
Old 09-15-2009, 05:10 PM   #9
Kevin245's Avatar
Most Mfgs. make their product data sheets available on line, and they usually state what materials should not be cleaned with their product (though not always).
The big thing to avoid are caustics such as Sodium Hydroxide. The other concern with chemicals is prolonged contact when they become trapped between faying surfaces of seams, or crevices. They can really attack some metals when given enough time.Just some random thoughts.
Hope this helps.
Old 09-15-2009, 05:31 PM   #10
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Ammonia will damage aluminum.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 10-06-2009, 06:36 PM   #11
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Send a message via AIM to jcanavera
Shari
Take a look at many car wash soaps and/or dishwashing liquids. Many contain a form of ammonia which can be detrimental to the clear coat and Alcoa finishes also.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.,'03 GMC Savana 2500,'08 Vespa GTS 250
Old 09-15-2009, 05:48 PM   #12
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
i've been told that silicone will react with the aluminum.
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
Old 10-06-2009, 06:08 PM   #13
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
Hopefully no one is using silicone as a cleaner
I don't know that silicone reacts with aluminum, but it's harder to get off than a duck on a junebug.
Pay no attention to the man behind the curtain- WoZ
Old 09-15-2009, 07:08 PM   #14
Profile:  1968 24' Tradewind
Oxford, , Mississippi
I just replaced all the windows and weather stripping in my Trade Wind. I found that lacquer thinner was the best in dissolving the old adhesive, tried all kinds of stuff. For the really dried stuff, Dremel has a scotchbrite buff you can chuck up in the Dremel and it get any residual adhesive and sealants. There are 2 grits, the course will scratch the Alum. skin if you get it on that but on the window frames they saved me hours and hours of scrubbing with 000 steel wool.
Aluminum-safe biodegradable washing solution ESCAPE POD Cleaning, Stripping & Polishing 8 07-03-2007 01:00 AM
Which chemicals do you prefer? nazz300 Community Polls 13 10-12-2006 04:48 PM
Household chemicals Yes, yes or No, No? thecatsandi On The Road... 3 03-27-2006 08:01 PM
Toilet chemicals gwsullivan Waste Systems, Tanks & Totes 33 02-24-2005 01:28 PM
Alumbright or other chemicals JohnG Cleaning, Stripping & Polishing 4 07-05-2004 08:37 AM
