Old 11-01-2013, 11:35 AM   #1
Meg
1960 22' Caravanner
Sonoma , California
Wet sanding using a AIr Compressor?
The compound F9 did not cut through the oxidation.
Now will try wet sanding with 800 g paper.
What do you think about using a sander, DA, 6'' with an air compressor?
MegHighway1 is offline   Reply With Quote
Old 11-01-2013, 12:09 PM   #2
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Please Don't
You could do irreparable damage to the skin of your Airstream.
I hope others will chime in.
There is so much info available on cleaning and polishing, please do your research.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 11-01-2013, 12:20 PM   #3
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Not advised wet sanding should be done by hand always.800 paper is to coarse,Start with 1500
Old 11-01-2013, 02:05 PM   #4
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
X2
HALT way too course I started with 600 and finished with 2000 on these....left them as is, no polish.
Name:	BATTERY DOOR CORROSION REPAIR 003.jpg
ID:	199124   Click image for larger version
Name:	BATTERY DOOR CORROSION REPAIR 007.jpg
Name:	BATTERY DOOR CORROSION REPAIR 011.jpg
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 11-01-2013, 02:05 PM   #5
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Polishing is not for the impatient...
But, if you don't want to sand w/1500 or finer by hand, try using a rouge or tripoli bar with your compounder. It'll cut through the oxidation - but it can also go too far. So take it easy, if you burn through the Alclad, the only way to "fix that" is replace the panel.
Shari
Old 11-02-2013, 10:08 AM   #6
Meg
1960 22' Caravanner
Sonoma , California
The pits are deep. Tom from Perfect Polish came over to take a look because I have been ordering compounds with him, and yes the pits are deep. NuviteF9 is not doing it and either is 3M Super Duty.
So the choices came down to:
1 wet sanding - I tried wet sanding over a square foot with 1000 and it did smooth out the pits. The color of the pits - little dark grey spots- remain. And the place that I sanded is pale and dull.
How do I know if I took off all the Alclad?
In the mean time I have been talking with car body shops that often use air compressors...which lead to the idea of using 1500 g with an air compressor so that I can limit the work on my good shoulder!
I do not want to cut the oxidation too much and remove the ALclad,which I am not sure what that would look like.
2) Pink and white emory bars may be better. Some say Black then brown then F9... What do you think? some say use a sisal wheel, others say use a grinding type buffer- not sure what those are.
But First...How do I know when sanding if the Alclad is OK.
(geez I wish there was a camp to learn this)
Meg
Old 11-02-2013, 11:03 AM   #7
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Yellow Jesco wheel and green bar. Then doubled up sewn cotton wheels with a Nuvite…your choice…G-6 or G-7…even C. Then Cyclo with S. Like Sherry said….not for the impatient.
Old 11-02-2013, 11:58 AM   #8
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Meg,
The camp is the Vintage Trailer Academy in Albuquerque in June.
http://vintagetraileracademy.com/
Bill
Meg
Just my personal opinion
