Old 09-29-2012, 05:10 PM   #1
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
WD40 as a polishing agent?
Spoke with a friend this week, and he reported that his neighbor "polishes" his AS with DW40? He just wipes it on to bring back the shine. Has anyone heard of this before?
Silverflames is offline   Reply With Quote
Old 09-29-2012, 05:46 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
One of the active ingredients of WD40 is phosphoric acid. Used often enough, or left on an Airstream trailer too long, it will cause pitting. Phosphoric acid is one of the acids used to etch the surface of aluminum before anodizing (at least according to ASTM D3933).
So, unless you're planning to paint your shiny Airstream, and want to make sure you get good adhesion of the paint, I would not recommend trying to use WD40 as an aluminum polish.
Try Brasso instead. It's a very gentle polish, used for brass-plated musical instruments and can be used on stainless steel, aluminum, chrome, pewter, bronze and copper as well as brass. Not, however, on sterling silver.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-29-2012, 05:59 PM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
wd 40 as a polish
WD 40 certainly is not a polish but it may increase the gloss on an Airstream that has a clearcoat or plasticoat. It offers no wax protection for the clearcoat. In the old days some people used to use a little Kerosene to give a gloss to old dull cars and then sold them quickly. I would not recommend WD 40 for this type of usage. Airstream has recommended a specific protective waxing compound for clearcoated trailers. I would follow their recommendations.
Old 09-29-2012, 06:39 PM   #4
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I use it on the rock guards ("segment protectors), but that's it. It cleans them, shines for a while and is easy to do.
Gene
Old 09-29-2012, 06:53 PM   #5
1969 29' Ambassador
Sounds like it might almost work as cheap acid wash, does not found like a good idea to use it long term.
Old 09-29-2012, 06:58 PM   #6
1981 31' Excella II
New Market , Alabama
I would think it would retard corrosion which is one of the reasons is was invented in the first place. It is not going to be as good as wax but it is better than nothing. There is nothing in it to polish metal. If used on a regular basis it should keep the metal from tarnishing or oxidizing. If I had one of the newer Airstreams with the non-Alclad skin, I would think about coating it with WD40 especially in corrosive enviroments like near the ocean. The solvents in WD40 may hurt the clear coat but I doubt it.
Perry
Old 09-29-2012, 08:11 PM   #7
But that doesn't necessarily mean that it's good for all metals.
WBCCI #1105
TAC LA-4
Old 09-29-2012, 08:11 PM   #8
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Ok, it may put a shine but its not going to last. I have used it on my stainless steal appliances in the house. It cleans and shines. But only for a few days. ( that may also have something to do with having for kids)
Any acid in it is going to be so small it would take years and years of use everyday to even start a microscopic pit it. IMO
It will work, but there are plenty of better things out there.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-29-2012, 08:18 PM   #9
Central , Mississippi
Pouring gallons of corn oil on the roof would leave a deep luster also but I'm pretty sure it's not a logical long term solution to a corroded aluminum trailer
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 09-30-2012, 09:39 AM   #10
Master of Universe
Gene's Avatar
WD40 is penetrating oil of some sort so dust sticks to it. It shines and cleans the lower rock guards for a while and works better than any metal polish I have.
I used to use it to spray on ignition wires to keep water vapor out. It worked well for that, but wires are better made today and seal well, so it isn't needed for that anymore. I spray it into the truck receptacle for the umbilical and it cleans it and doesn't affect electrical flow, but I wouldn't spray it on the body of the trailer unless I was getting grease off. Then I'd wash and wax the trailer.
Gene
Old 09-30-2012, 11:09 AM   #11
Yeah. The "WD" in the name stands for "Water Displacing," I think.
WBCCI #1105
TAC LA-4
Old 09-30-2012, 11:44 AM   #12
Master of Universe
Gene's Avatar
Very close: "Water Displacement, 40th Formula": WD-40 - Wikipedia, the free encyclopedia
I read this once before and couldn't remember even Water Displacing. Great stuff, but not a polish.
Gene
Old 09-30-2012, 12:30 PM   #13
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Exactly right on water displacement. As testimony to its effectiveness, I recall my father having an old truck that was a total pain to get started with any moisture present. Show it a puddle, and it was done for the day. I watched as he would open the hood and simply spray WD40 all over everything without pulling wires or removing the distributor cap. The truck would start right up. It made a believer out of me. I've also seen it used to set the bead on a truck tire in the wilderness by taking advantage of its explosive qualities. Not something to attempt in the garage at home.
streamquest is offline   Reply With Quote
Old 09-30-2012, 12:36 PM   #14
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
We used to use starting ether to set the bead on big truck tires until a friend rolled his truck. It was blamed on ether remaining in thr tire and exploding as he was barreling down the interstate. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Interior Polishing Aktundra 1961 - 1963 Bambi 13 09-22-2013 11:46 PM
Polishing in Central Texas area GeoStreamer Cleaning, Stripping & Polishing 4 09-27-2011 05:38 PM
