Old 09-30-2012, 07:44 PM   #15
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
He must have used an awful lot of fluid to leave enough remaining in the tire after the initial blast to cause a secondary explosion. ouch.
streamquest is offline   Reply With Quote
Old 09-30-2012, 09:30 PM   #16
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
After seating the bead like that, you need to deflate the tire again to vent the vapors, then re-air it, before putting the tire on the vehicle. Once the bead is seated, it should stay seated even when you let the air back out.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-08-2012, 02:41 PM   #17
dcasr's Avatar
1990 29' Excella
Stone Mountain , Georgia
What can I use to get the glue reside of old numbers, stars, etc. off of the front and back of my 1990 Excella?
I have tried soap, hot air from hair dryer, mineral spirits, truck box polish, goo gone and nothing is budging the residue. Used some truck box polish and my porter cable polisher, but that hasn't made much difference either. Help!
dcasr is offline   Reply With Quote
Old 10-08-2012, 11:48 PM   #18
tinyhome's Avatar
Victoria , Texas
Wouldn't that be nice if all it took for a nice polished airstream was a can of wd40!
tinyhome is offline   Reply With Quote
Old 10-09-2012, 11:13 PM   #19
1936 20' Clipper
1947 22' Liner
Curtis Wright
I've always been a big fan of lacquer thinner. You might also consider a paint stripper by Jasco, but that will take off your clear-coat for certain, and attack almost anything that it contacts. Keep it away from plastic parts such as light lenses, etc.
Old 10-10-2012, 02:09 AM   #20
2007 30' Classic S/O
Kenton , Ohio
When I was at Jackson Center to ask them what to use to remove the bugs and do a quick detail of the airstream they told me to use wd40. I tried it. It does work ok. It is not the same as a wax or polish. But it does provide a nice sheen.
Wiremanranch is offline   Reply With Quote
Old 10-10-2012, 05:15 AM   #21
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
The explosive power of any spray can is mostly the propane propellant, not the active product (in this case WD-40).
When on the farm and using propane powered vehicles, we had an air hose plumbed into a vapor port of the propane tank to fill flat tires. Lots of folks did. I've never seen a propane filled tire cause a problem. We did mention it to the tire shop when having it repaired, though.
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Interior Polishing Aktundra 1961 - 1963 Bambi 13 09-22-2013 11:46 PM
Polishing in Central Texas area GeoStreamer Cleaning, Stripping & Polishing 4 09-27-2011 05:38 PM
