Old 05-30-2008, 10:57 AM   #1
1994 30' Excella
1973 25' Tradewind
wilmington , North Carolina
Wd40
I recently stayed at Willow Tree Campground near Myrtle Beach, and upon leaving I met a man that said he sold airstreams in Florida for many years. He said the best way to clean one up was with WD40 , the whole exterior they would spray down.
Does this sound like good advice?
I should keep Willow Tree a secret.........
sluggo is offline   Reply With Quote
Old 05-30-2008, 12:32 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Not a chance on my new(er) Airstream....maybe on the older ones without the Aloca coating......
Old 05-30-2008, 12:40 PM   #3
Uberphotos's Avatar
1968 22' Safari
Kalamazoo , Michigan
We used a light coating to polish high-end racing bikes (mountain bikes and road bikes) when I worked in a bicycle shop...it gave a real slick shine to the bike (that was aluminum)...I just might have to try it on a hidden spot to see how it works on my Safari.
'68 Safari Land Yacht, Double
Check out my blog... http://ssairstream.blogspot.com/
Uberphotos is offline   Reply With Quote
Old 05-30-2008, 12:47 PM   #4
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
I would be concerned about using it on the coated aluminum on my newer AS too. I do use it on the stainless steel rock guards though and it polishes those up nicely.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 05-30-2008, 02:03 PM   #5
flitzwhopper's Avatar
1976 Argosy 24
Tempe , Arizona
from a car guy
WD-40 is a light machine oil. While it is pretty good as a solvent, it has a tendency to fix fine dust and convey it into nooks and crannys (technical terms). That's why, after freeing up a sticky part with WD40, my experts recommend following with a little ATF to provide more permanent lubrication. I would guess that WD40 would do a good job of cleaning off the surface of aluminum parts. However, incorporating fine dust onto surface of your unit may not be the exactly what you have in mind. Hard surfaces such as steel are probably less affected but clear coated aluminum may be a different story.
Donna & Mike
Cowboy up! or go sit in the truck
Charter Member Four Corners Unit
WBCCI #2417
flitzwhopper is offline   Reply With Quote
Old 05-30-2008, 02:27 PM   #6
RIstream'n's Avatar
2008 27' Safari FB SE
Cumberland , RI
Did you know WD40 was invented by NASA??? It took 40 attempts to get it right and it's water dissolvable hence the name WD40......
Brian & Donna
08 27' Safari FB SE
03 Avalanche 2500
WBCCI #1199 - AIR #23847
NEU
LIFE IS GOOD
RIstream'n is offline   Reply With Quote
Old 05-30-2008, 02:29 PM   #7
sander17's Avatar
1996 28' Excella
Okemos , Michigan
Images: 42
WD-40 and Swoopy graphics:
When the Swoopy graphics started pealing off our 96 excella, WD-40 turned out to be the best solvent for the residue adhesive. It did not affect the clearcoat underneath. I tried several other solvents at hidden locations and was surprised how many of them just dissolved the clearcoat.
Dave
Okemos, MI
T.V.:'05 Dodge Ram 2500 4x4 Quad Cab Cummins
AIR#2276
sander17 is offline   Reply With Quote
Old 05-30-2008, 02:33 PM   #8
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
It's the best for removing adhesive from labels and what not. I use it for that but not as an overall protective or polishing coating.
And I'm glad I chose not to get the graphics on my Safari!
Old 05-30-2008, 02:35 PM   #9
sander17's Avatar
1996 28' Excella
Okemos , Michigan
Images: 42
see
WD-40 Company and Product History
It was the Rocket Chemical Company, not NASA that invented it, for Atlas missiles. The hard part was keeping the employees from taking it home at night!
Dave
Okemos, MI
AIR#2276
Old 05-30-2008, 02:53 PM   #10
phoenix491's Avatar
1965 20' Globetrotter
Keller , Texas
And now you know the REST of the story ... good day.
phoenix491 is offline   Reply With Quote
Old 05-30-2008, 03:21 PM   #11
vhord's Avatar
Images: 96
That sould be "water displacement" I think.
vhord is offline   Reply With Quote
Old 05-30-2008, 04:24 PM   #12
HowieE's Avatar
Princeton , New Jersey
Images: 12
Rule of thumb.
If it is not supossed to move and does Duct Tape it.
If it is supposed to move and does not WD40 it.
2004 Excursion 4x4
Old 05-30-2008, 05:19 PM   #13
Images: 14
WD40 - thumbs up
I've used it for years to clean the underside of my show cars. The bottom of the floor pan is painted in primer and WD40 has not hurt that paint. It disappears/evaporates in a couple of day.
I've hear the "use it to clean an Airstream" story from Bates' (Airstream dealer in Tampa) customers.
My quess is that it wouldn't hurt the clearcoat.
bjond is offline   Reply With Quote
Old 05-30-2008, 06:51 PM   #14
RIstream'n's Avatar
Cumberland , RI
see
According to the people at Kennedy space center they invented it. Oh well maybe they were wrong
Brian & Donna
08 27' Safari FB SE
03 Avalanche 2500
NEU
LIFE IS GOOD
Wd40!!!!!!! jjonesnc General Repair Forum 45 06-17-2004 06:11 AM
