Old 07-11-2004, 01:47 AM   #1
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Unhappy Water spots...how to remove or prevent?
I'm in the process of polishing my Caravel with Southern Shine. It's going well except that the water I'm using to clean it with is hard well water and is leaving stubborn water spots on the finish, even after waxing. I'm thinking rainwater might do the same. The spots won't wipe or buff off after they've set in. Must be some kind of chemical reaction. I've had to re-sand them off a couple of areas and re-polish.
Any suggestions?
Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
Rog0525 is offline   Reply With Quote
Old 07-11-2004, 04:54 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Rog9525!
A method that I suggested to a neighbor at the WBCCI International Rally in Sioux Falls, SD often works in easily removing hard water spots from surfaces. Mix a strong solution of white vinegar and water (between 1 pint and 1 quart of vinegar to one gallon of water) then wipe down the panel with a rag dampened in the solution. It may not work under all circumstances, but did with the recently polished Soverign that my neighbor owed.
Good luck with solving your water spotting problem!
Kevin
Kevin D. Allen
AIR #827
water system mystery garymacf Plumbing - Systems & Fixtures 4 06-21-2003 11:50 AM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
Darned water spots! Charcigar Cleaning, Stripping & Polishing 6 07-30-2002 02:29 PM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
