Old 01-31-2013, 04:46 PM   #1
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Water Heater Access Door - Polished Look
Our Airstream has been stripped and polished.
I recently replaced the Atwood 6 gallon water heater. It comes with a shinny new access door in gleaming white!
What do folks with polished Airstreams do with the water heater access door? It is stamped sheet steel.
David
Old 01-31-2013, 04:51 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
David
Stainless steel....Also for furnace, fridge and stove vent doors.
Only place to get them now is at the AS Store.
Name:	STAINLESS UP-GRADES 002.jpg
ID:	177829   Click image for larger version
Name:	STAINLESS UP-GRADES 006.jpg
Name:	STAINLESS UP-GRADES 012.jpg
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
ďItís a crooked piece of time that we live inÖ.Ē
John Prine
Old 01-31-2013, 05:42 PM   #3
Snedwid's Avatar
2011 23' FB Flying Cloud
Perry , Florida
Nice looking stuff!!! Definately on the want list.
"If you don't know where you are going, you will wind up somewhere else." Yogi Berra
Snedwid is offline   Reply With Quote
Old 01-31-2013, 06:13 PM   #4
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
I was able to reuse my original water heater cover when I installed a new Suburban heater in my '67.
Fortune cookie say....."Prudence keeps life safe, but does not often make it happy."
Diesel1 is offline   Reply With Quote
Old 02-01-2013, 08:16 AM   #5
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
The Atwood white access door is magnetic, so I assume it is stamped steel. Stainless steel can be polished to a mirror finish. You see stainless steel mirrors in campground bathrooms as they are very durable. Stainless would be a lot harder to polish than aluminum.
I just thought having a polished water heater access door would look better than a stamped steel one. Maybe I could laminate an aluminum cover over the door and polish that to look like the rest of the trailer?
Has anyone seen mirror polished water heater access doors and if so, how was it achieved?
David
Old 02-01-2013, 10:31 AM   #6
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Robert,
I installed a set of these recently too and found it a bit challenging to leave a little gap between the panel and the aluminum siding. I think its important so you dont have dissimilar metals touching... not that we dont already have corrosion concerns :-(
How did you handle that with your install?
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 02-01-2013, 11:14 AM   #7
Thumbs up
Vinnie,
The only one I was leery of was the stove hood vent, more for leaking than a corrosion problem. I used a length of 1/4" od clear plastic tubing, split to fit over edge to help seal.
I installed the covers several years ago, no hint of corrosion so far.
PFC
"Tahawus"
RLC
John Prine
Old 02-01-2013, 11:24 AM   #8
moderator
Airslide's Avatar
Wilton , California
Images: 50
Originally Posted by ROBERT CROSS View Post
Vinnie,
I knew you would have a good solution! Thx.
Old 02-01-2013, 12:18 PM   #9
I had my white Atwood over painted with silver urethane and clearcoated
From a body shop that was shooting another car silver that week, I asked
manager if I could get them to shoot my cover while they had the same paint
Match and sprayer set up. He charged me $75 to paint the Atwood cover and
The horizontal propane tank cover on my 34 footer. They even sanded And primed them. Still holds up well to this day and that was in 2007.
0557 is online now   Reply With Quote
Old 02-02-2013, 10:18 AM   #10
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I tried rattle can paint but didn't like the surface. It was quite soft. I scratched it with a paper towel. Automotive paint and clear coat would have much better durability. It is an option.
David
