I've gone through one bundle of cyclowraps and started on the second one. I have heard about taking them to a local coin laundry and running them through the washer. My question is, regular detergent or what? Hot water, warm or cold? Clorox or not? Fabric softener or not? Delicate dry or air dry? I've got the home laundry down pat but this is a little different.
I took a couple wraps to the laundry not long ago, washed in warm water, no Clorox, no fabric softener and the wraps came out a little stiff after the dryer.
__________________ Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Have not yet dared to go to the Coin Op with mine yet, figure I'll get run hour of there with those things!
Interested in knowing how you make out tho!
'74 Overlander (Rear Bed)
'77 20' Argosy MH (Looking for a new home)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281 w) www.balrgn.com www.balrgn.com/Airstream.htm
AIR #0078
3.73 rear end
I soak mine in a bucket of cold water and a quarter cup of tsp for two days.They come out clean.I do the same with my wool bonnets.They can then be thrown in with regular wash but will shrink.Could be rinsed well and hung up to dry.I dry the wool bonnets by spinning in polisher with bonnet in a bucket.Works great and no shrinking.
I washed mine at home with warm water and regular laundry soap. I used fabric softner in the dryer. I also ran a empty cycle through the washer after and then cleaned up with 409. Of course I washed my polishing clothes in the next load for insurance. This has been repeated several times with no black being transfered to our clothes.
AIR #0078
3.73 rear end
